IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6216 Views
  • 14 replies
Hi,I have a lot of end-users in our Cisco Unified Communication Manager 7.x installation, but many of them are leftovers from the older CUCM installation that we upgraded from.Is there any way that I can see when a given end-user was created in the C...
Upgrading from CUCM 7.1.3.32900-4to CUCM 7.1.5.32900-2two hours into the process, I received this message in status windowThe application has lost communication with the system.  Check the status using CLI.When I entered commandutils system upgrade s...
tsperduto by Level 1
  • 1349 Views
  • 1 replies
Resolved! FXS vs FXO
Hi all,I'm currently studying for CCVP and i'm struggling to summarise the differences between FXS and FXO ports - ie what I can connect to what, such as phones, other PBX's, and which port can be used (via a lead) to which kind of port.Any help on t...
Hi,message waiting indication is now working on newly created ip phone.all other ip phone it is working it is not working on only one phone whichi snewly created. i suspect the configuration what i did. please help me by proviidng the steps to be fol...
baskaranm by Level 1
  • 561 Views
  • 5 replies
We are preparing to upgrade from 7.1.2 to 7.1.5, we have 6 nodes in this cluster, with approx 2500 phones.  How long should the install take on each server?  We will upgrade the inactive one evening and boot to it the following evening.
Has anyone connected a SPA8000 with CUCM? I'm a little confused as to how you would setup the numbers, and what to do about only having one MAC address.If anyone has any details about how to get these two to work together would be great (the more det...
b0otable7 by Level 1
  • 1598 Views
  • 2 replies
