01-23-2015 09:01 PM - edited 03-17-2019 01:43 AM
Hi All,
We are turning up a LD PRI in a site ..but even after turning up the D channel it is not coming up. The switch type is primary ni2.
Below is the current status
ISDN Serial0/2/0:23 interface
dsl 2, interface ISDN Switchtype = primary-ni
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 2 CCBs = 0
The Free Channel Mask: 0x00000000
Number of L2 Discards = 0, L2 Session ID = 18
Total Allocated ISDN CCBs = 0
Controller-
controller T1 0/2/0
fdl both
cablelength long 0db
pri-group timeslots 1-24
description T1/PRI XXXXXXX
interface Serial0/2/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
no cdp enable
The interface is constantly going up and down constantly showing loss of frame.
do we need to connect crossover cable or something?
01-23-2015 09:03 PM
Doing a terminal monitor
*Jan 24 04:54:01.448: %CONTROLLER-5-UPDOWN: Controller T1 0/2/0, changed state to up
*Jan 24 04:54:03.448: %LINK-3-UPDOWN: Interface Serial0/2/0:23, changed state to up
*Jan 24 04:54:04.448: %CONTROLLER-5-UPDOWN: Controller T1 0/2/0, changed state to down (LOF detected)
*Jan 24 04:54:04.448: ISDN Se0/2/0:23 Q931: L3_ShutDown: Shutting down ISDN Layer 3
*Jan 24 04:54:04.452: ISDN Se0/2/0:23 Q931: Ux_DLRelInd: DL_REL_IND received from L2
*Jan 24 04:54:06.448: %LINK-3-UPDOWN: Interface Serial0/2/0:23, changed state to down
*Jan 24 04:54:07.448: %CONTROLLER-5-UPDOWN: Controller T1 0/2/0, changed state to up
*Jan 24 04:54:09.448: %LINK-3-UPDOWN: Interface Serial0/2/0:23, changed state to up
*Jan 24 04:54:11.456: ISDN Se0/2/0:23 Q931: Ux_DLRelInd: DL_REL_IND received from L2
*Jan 24 04:54:12.448: %CONTROLLER-5-UPDOWN: Controller T1 0/2/0, changed state to down (LOF detected)
*Jan 24 04:54:12.448: ISDN Se0/2/0:23 Q931: L3_ShutDown: Shutting down ISDN Layer 3
*Jan 24 04:54:14.448: %LINK-3-UPDOWN: Interface Serial0/2/0:23, changed state to down
01-23-2015 11:42 PM
seems to be a framing issue logs show loss of frame [LOF]
what is the framing[sf/esf] and CRC4 u have configured under controller ?
regds,
aman
01-24-2015 08:20 AM
T1 0/2/0 is down.
Applique type is Channelized T1
Cablelength is long 0db
Description: T1/PRI XXXX
Transmitter is sending remote alarm.
Receiver has loss of frame.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Failure
Version info FPGA Rev: 08121917, FPGA Type: PRK4
Framing is ESF, FDL is ansi & att, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
01-24-2015 09:09 AM
Hi Shyam,
It would be better if u speak to TELCO and get the parameters to be configured for T1 Controller.
regds,
aman
01-24-2015 12:05 PM
Hi Shyam.
+5 to my buddy Aman.
I also would try theese two commands:
network-clock-select 1 T1 0/2/0
Also check cabling between your VG and TELCO Equipment
Carlo
