ISDN q931 Failor
Hi all,
i have a customer with an old PBX System,l so i have to install a UC520 System. 8.0.2 System Image.
Line: ISDN with Multidevice Configuration
When the UC generate a new call all works in normal set conditions
But incoming calls not work
Here the Config of the BRI Voice Ports an Translation Rules:
isdn switch-type basic-net3
voice translation-rule 1
rule 1 /\(^.*\)/ /00\1/ plan isdn national
voice translation-rule 2
rule 1 /^xxxxxx6$/ /12/
rule 2 /^xxxxxx8$/ /19/
voice translation-rule 3
rule 1 /^1[0-8]/ /xxxxxx6/ type any national plan any isdn
rule 2 /19/ /xxxxxx8/ type any national plan any isdn
voice translation-profile incoming
translate calling 1
translate called 2
voice translation-profile outgoing
translate calling 3
interface BRI0/1/0
no ip address
isdn overlap-receiving
isdn incoming-voice voice
isdn sending-complete
interface BRI0/1/1
no ip address
voice-port 0/1/0
translation-profile incoming incoming
translation-profile outgoing outgoing
echo-cancel coverage 32
compand-type a-law
cptone DE
bearer-cap Speech
voice-port 0/1/1
compand-type a-law
cptone DE
bearer-cap Speech
q931 LOg:
Nov 12 16:39:39.287: ISDN BR0/1/1 Q931: RX <- SETUP pd = 8  callref = 0x01
    Sending Complete
    Bearer Capability i = 0x8090A3
        Standard = CCITT
        Transfer Capability = Speech
        Transfer Mode = Circuit
        Transfer Rate = 64 kbit/s
    Channel ID i = 0x89
        Exclusive, B1
    Called Party Number i = 0xC1, 'xxxxxx6'
        Plan:ISDN, Type:Subscriber(local)
    High Layer Compat i = 0x9181
Nov 12 16:39:39.299: ISDN BR0/1/1 Q931: TX -> CALL_PROC pd = 8  callref = 0x81
    Channel ID i = 0x89
        Exclusive, B1
Nov 12 16:39:39.315: ISDN BR0/1/1 Q931: TX -> DISCONNECT pd = 8  callref = 0x81
    Cause i = 0x809C - Invalid number format (incomplete number)
Nov 12 16:39:39.387: ISDN BR0/1/1 Q931: RX <- RELEASE pd = 8  callref = 0x01
Nov 12 16:39:39.391: ISDN BR0/1/1 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x81
KF-UC520#
Nov 12 16:40:10.975: ISDN BR0/1/1 Q931: RX <- SETUP pd = 8  callref = 0x01
    Sending Complete
        Standard = CCITT
    Channel ID i = 0x89
        Exclusive, B1
    Calling Party Number i = 0x2183, 'xxx'
        Plan:ISDN, Type:National
    Called Party Number i = 0xC1, 'xxxxxx8'
Nov 12 16:40:10.987: ISDN BR0/1/1 Q931: TX -> CALL_PROC pd = 8  callref = 0x81
    Channel ID i = 0x89
        Exclusive, B1
Nov 12 16:40:11.003: ISDN BR0/1/1 Q931: TX -> DISCONNECT pd = 8  callref = 0x81
Nov 12 16:40:11.079: ISDN BR0/1/1 Q931: RX <- RELEASE pd = 8  callref = 0x01
Nov 12 16:40:11.083: ISDN BR0/1/1 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x81
1. MSN One no how is calling info and  0x809C - Invalid number format (incomplete number)
2. MSN Two 0x809C - Invalid number format (incomplete number)
I test various setting of type and plan but with no success
Is there in the Config an error or has someone an idea ?
Philipp
paolo bevilacqua
Start updating software to latest, as old has many bugs.
