ISM-SRE-300-K9 - Unity express 8.5.1 installation
rajesh.kumar
Level 4
Level 4
I am getting following error on Unity Express, during, service-module ISM0/0 session from CME
Secondary Boot Loader authenticated - booting....
Please enter '***' to change boot configuration:
Detect and Initialze network device
Backup current platform configurations....
SRE step 1 - SM registration...
Response - no installation needed (len: 422)
SRE Installation Not Needed
Loading disk:/bzImage ... done.
Unable to load image
Unable to boot image
I belive boot image is corrupt.
I want to install CUE 8.5.1
I will be using this method,
#service-module ism 0/0 install url ftp://username:password@x.x.x.x/dir/cue-vm-xxxx8.5.1.pkg
I am quite confused, which file should I download from cisco.com for CUE fresh installation.
is it, cue-installer.sme.8.5.1 or cue-vm-k9.sme.8.5.1.zip ?
single file will reinstall CUE ?
Rgds
Rajesh
ronpatel
Level 8
Level 8
You Need cue-vm-k9.sme.8.5.1.zip for the installation.
Below lik has procedure mentioned.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel8_5/install/upgrade.html
Ronak patle
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
