ISR 4331 Voice Gateway configuration
gary391
Hi Team,
I am new to the Cisco domain. I have been tasked with investigating and configuring an ISR4331 as a voice gateway. We are currently using AudioCodes Voice Gateways and want to include Cisco ISR 4331 as a voice gateway option in our fleet.
I have a few basic questions to get started.
1. Does ISR4331 support PRI and SIP trunk integration?
2. I have Cisco 3845 as a voice gateway (PRI); can I use its configuration on ISR4331?
3. Can someone suggest a good configuration doc., that can help me get started on my project?
Thanks & Regards,
1. Yes
2. More or less you can use the same configuration. There can be some differences between the two platforms, but you should be able to figure it out by looking for any error(s) you get.
3. Look at this document. Cisco Unified Border Element Configuration Guide Through Cisco IOS XE 17.5
Response Signature
1. Yes
Response Signature
