ISR 4351 GE Port
foued kh
Hi team,
For an ISR 4351, there is GE ports onboard the router.
My question is ; Do I need RJ45 module that I have to purchase with the router or it will be delivered with rj45 module by default?
Thank you in advance
Manish Gogna
Hi Foued,
As per the ISR 4000 series ordering guide "The default accessory kit does not include any Category 5 RJ-45 Ethernet cables or cables for the router console or auxiliary port. You can order the console and auxiliary cables as an option during router configuration or as spares."
http://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/guide-c07-732797.html
So you may need to order it separately.
Manish
