Issue facing with Conference call
Vijay Patil
Level 3
Level 3
please suggest is the below mention configuration for IP Phone will be ok ..or do i need to add any other parameter
I am facing issue with the conferencing on SCCP phone  where it is Model 7945
ephone  2
mac-address D4A0.2A89.D388
max-calls-per-button 2
busy-trigger-per-button 2
ephone-template 1
presence call-list
type 7945
missed-calls all
keep-conference
button  1:2 2:50
ephone-dn  2  dual-line
number 9941
label TesTing-2
name TesTing-2
ephone-dn  50
number 9942
9 Replies 9
dwayne rattan
You are trying to conduct an ad-hoc conference ? The Max call and busy trigger values will only allow two calls you will need to raise the values. The below values determine how many calls can be placed on hold or how many call waiting will be available.
max-calls-per-button 4
busy-trigger-per-button 4
I have not done my home work on all the details of this model but it should be able to go up to 6 calls
You need to configure hardware conference as well otherwise by default you will be able to do 3 party conference only.
Suresh
Jaime Valencia
Saying something doesn't work, without a proper explanation of the behavior, and what you have configured is futile. For a conferencing problem, the phone config is the least important part of this, how the conferencing is configured, is what needs to be reviewed.
ad-hoc?? meet-me??
Have you properly configured conferencing on CME?? The CME config guide has all the requirements, depending on what you're using, SW or HW.
java
if this helps, please rate
HEllo Jaime,
Thanks for replay
We are using CME 11.5 on Cisco 2951/K9
as per the cisco Docs e configured "Three-Party Ad Hoc Conferencing"
below is what we configured on CME ..& SCCP Phone configuration is already shared..
is this will be enough...& still it is not working how can we troubleshoot on this .
telephony-service
 sdspfarm conference mute-on * mute-off *
 sdspfarm units 5
 sdspfarm transcode sessions 128
 sdspfarm tag 1 conference
 conference hardware
 no auto-reg-ephone
 max-ephones 164
 max-dn 450
 ip source-address 10.20.233.10 port 2000
 service phone webAccess 0
 service directed-pickup gpickup
 system message mGage Bangalore
 url directories http://10.20.48.77:8091/ldap/start.php
 url services http://10.20.48.77:8091/ldap/start.php root
 load 7911 SCCP11.9-4-2SR2-2S
 time-zone 39
 time-format 24
 max-conferences 4 gain -6
 moh enable-g711 "music-on-hold.au"
 transfer-system full-consult
 fac standard
 create cnf-files version-stamp 7960 Feb 08 2017 14:02:14
No, you're still missing conferencing related config.
You need to post ALL the conferencing config.
java
HEllo,
Attached is the VGW configuration ...Conferencing working for SIP Phone but not for SCCP
Post the output of:
show ephone-dn conference
java
Hello Jaime...
below is the output
VGW#sh ephone-dn conference
type         active inactive  numbers
Ad-hoc          0       8      777
Any way issue was resolved ...& we are now able to make conference with SCCP IP Phones
    Changed command  ‘sdspfarm tag 1 conference’ to ‘sdspfarm tag 2 conference’ under Telephony-Service
    where
dspfarm profile 1 transcode
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec g729br8
 codec g729r8
 maximum sessions 1
 associate application SCCP
dspfarm profile 2 conference
 codec g729br8
 codec g729r8
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 maximum sessions 5
Hello Jaime,
pls find the VGW confog
