03-14-2018 10:46 AM - edited 03-18-2019 12:23 PM
Hello every one i have issue in DTMF between the Cucm And Quescom GSM Gateway when i use webex call me option the call out from the quescom gateway and i resived it in Cell phone but the When i press 1 the webex didn't not responed i think it problem in DTMF i try using Cisco Gateway using PRI the DTMF work fine
i try in intercluster Trunk or sip trunk between cucm and quescom i try all dtmf option in quescom and cucm
can any one help me to solve this issue
03-14-2018 11:35 AM
Review CUCM traces and confirm CUCM does send the DTMF, if it does, then you'll have to review how to get your quescom to forward the DTMF CUCM is sending.
03-14-2018 05:16 PM
Try to get it to work, using a SIP trunk, check if you either need to use inband RFC2833 DTMF or Sip-notify DTMF. make and inbound call into your quescom and see which one it is using, and set up your cucm accordingly.
03-19-2018 09:02 AM
i try this solution but didn't solve the issue
also i try add mtp to the trunk and didn't work
