issue of personal communicator
ankur
I am using presence server and I have integrated with call manager.I am able to login with personal communicator but it showing offline.
Can you please tell me how can i use personal communicator.Is there any configuration issue in presence?Please tell me.
Ankur Tyagi
nitsinha
Level 4
Level 4
Which version of CUPS server and the CUPC client are you using? When you login to the CUPC client, check Help>>show server health. Is the presence connected?
Nitesh
We are using cups 7.0.6.10000-17 .
Presence is not connected with cupc client.
How can i connect cupc client with presence.
Thanks & regards
Ankur Tyagi
Quoting nitsinha :
ANKUR TYAGI,
A new message was posted in the Discussion thread "issue of personal
communicator":
https://supportforums.cisco.com/message/3348548#3348548
Author : Nitesh Sinha
Profile : https://supportforums.cisco.com/people/nitsinha
Message:
The version of cups is 7.0.6.10000-17.cupc client is also version 7.
please find the attachment for more detail.
Ankur Tyagi
Quoting nitsinha :
ANKUR TYAGI,
communicator":
Message:
Have you gone thru all the steps to provision the CUPC?
Cisco Unified Presence, Release 7.x --  Deployment of Cisco Unified Presence
http://docwiki.cisco.com/wiki/Cisco_Unified_Presence,_Release_7.x_--_Deployment_of_Cisco_Unified_Presence
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
