issue with cisco ip phone 7962 when using headset
douglasmhines
i have successfully mated the plantronics CS55 headset with the cisco IP phone 7962.  now my only issue is, when i use the headset, the audio sound is still being sent to the hand held receiver.  did i configure it incorrectly?  i don't think so as i am using both ports on the back of the phone (one for the headset and the other for the hand-held receiver).  i am thinking there must be a way to have the audio signal not sent to the handset when i use the headset.
any ideas?
currently i am just unplugging the cord into the handset when i use the headset, but that is quite annoying.
many thanks in advance for any help.
Rob Huffman
Hi Douglas,
You are likely seeing this
CSCsr65970            Bug Details
Feature to turn on/off audio played to handset while on headset
Symptom:
If you hear closely, the phone will play the audio to headset and handset simultaneously
at all times.
Conditions:
It happens on all phones until firmware 8.3(5)
Workaround:
None
StatusStatus
Terminated
Severity Severity
6 - enhancement
Last Modified Last Modified
In Last Year
Product Product
Cisco Unified IP Phone 7900 Series
Technology Technology
1st Found-In 1st Found-in
8.3(5)
8.5(2)
If the handset is "On Hook" with the volume down a bit the problem doesn't seem to bother our users
who use the CS55 (I use one as well)
Cheers!
Rob
many thanks for taking the time to respond.  i will forward this info onto our userbase.  hopefully at some point in the future the software will be modified to prevent this from happening . . .
thanks again.
