10-19-2012 07:16 AM - edited 03-16-2019 01:47 PM
I am installing a brand new 2901 with CME and I can not get any phones to register. The phones upgrade their Firmware just fine so I have IP connectivity. But they are just stuck in Registering. I turned on debug ephone detail, and I see nothing. I am running Version 152-3.T2 with version CME 9.0, is there something new with 9.0 that I have not turned on maybe? Here is a snipit of my config.
Current configuration : 10597 bytes
! Last configuration change at 03:58:06 EST Fri Oct 19 2012 by admin
! NVRAM config last updated at 16:39:03 EST Thu Oct 18 2012 by admin
version 15.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.152-3.T2.bin
boot-end-marker
ip dhcp excluded-address 10.100.182.1 10.100.182.30
ip dhcp excluded-address 10.100.182.128 10.100.182.150
ip dhcp pool Data
network 10.100.182.0 255.255.255.128
default-router 10.100.182.1
dns-server 10.100.182.20 10.100.101.10
lease 7
ip dhcp pool Voice
network 10.100.182.128 255.255.255.128
default-router 10.100.182.129
option 150 ip 10.100.182.129
lease 7
voice-card 0
dspfarm
dsp services dspfarm
voice rtp send-recv
voice service voip
ip address trusted list
ipv4 0.0.0.0 0.0.0.0
dtmf-interworking rtp-nte
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
h323
sip
bind control source-interface GigabitEthernet0/0.10
bind media source-interface GigabitEthernet0/0.10
rel1xx disable
header-passing
error-passthru
early-offer forced
midcall-signaling passthru
sip-profiles 100
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class h323 1
h225 timeout tcp establish 3
h225 timeout setup 3
voice class sip-profiles 100
response ANY sdp-header Audio-Attribute modify "sendonly" "sendrecv"
request ANY sdp-header Audio-Attribute modify "sendonly" "sendrecv"
license udi pid CISCO2901/K9 sn FTX163084E4
hw-module ism 0
hw-module pvdm 0/0
interface Null0
no ip unreachables
interface Embedded-Service-Engine0/0
no ip address
shutdown
no ip address
duplex auto
speed auto
encapsulation dot1Q 1 native
ip address 10.100.182.1 255.255.255.128
encapsulation dot1Q 10
ip address 10.100.182.129 255.255.255.128
interface ISM0/0
ip unnumbered GigabitEthernet0/0.10
service-module ip address 10.100.182.130 255.255.255.128
!Application: CUE Running on ISM
service-module ip default-gateway 10.100.182.129
interface GigabitEthernet0/1
ip address 192.168.100.9 255.255.255.0
duplex auto
speed auto
interface ISM0/1
description Internal switch interface connected to Internal Service Module
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
no ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
ip route 0.0.0.0 0.0.0.0 192.168.100.1
ip route 10.100.182.130 255.255.255.255 ISM0/0
logging trap debugging
tftp-server flash:apps37sccp.1-4-4-0.bin
tftp-server flash:apps42.9-2-1TH1-13.sbn
tftp-server flash:cnu42.9-2-1TH1-13.sbn
tftp-server flash:cvm42sccp.9-2-1TH1-13.sbn
tftp-server flash:dsp42.9-2-1TH1-13.sbn
tftp-server flash:jar42sccp.9-2-1TH1-13.sbn
tftp-server flash:SCCP42.9-2-1S.loads
tftp-server flash:term42.default.loads
tftp-server flash:term62.default.loads
control-plane
mgcp profile default
dial-peer voice 10 voip
description **CUE Voicemail**
translation-profile outgoing PSTN_CallForwarding
destination-pattern 6000
b2bua
session protocol sipv2
session target ipv4:10.100.182.130
dtmf-relay sip-notify
codec g711ulaw
no vad
gatekeeper
shutdown
telephony-service
max-ephones 15
max-dn 30
ip source-address 10.100.182.129 port 2000
calling-number initiator
load 7937 apps37sccp.1-4-4-0.bin
load 7942 SCCP42.9-2-1S
load 7962 SCCP42.9-2-1S
time-zone 12
voicemail 6000
max-conferences 12 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh "music-on-hold.au"
transfer-system full-consult dss
transfer-pattern 9.T
secondary-dialtone 9
create cnf-files version-stamp 7960 Oct 18 2012 18:21:28
ephone-dn 11 dual-line
number 1201 secondary 2023707880 no-reg both
name Wall Mart Main Number
call-forward busy 6000
call-forward noan 6000 timeout 15
ephone 1
device-security-mode none
mac-address 001D.452D.552D
type 7942
button 1:11
ephone 2
mac-address 001D.A23E.A1C6
type 7942
button 1:11
ephone 3
mac-address 001D.45B6.804F
type 7961
button 1:11
10-19-2012 07:53 AM
Can you post "debug tftp events"
Chris
10-19-2012 08:28 AM
Here it is.
FP-2901#debug tftp events
TFTP Event debugging is on
FP-2901#
FP-2901#
FP-2901#
005163: Oct 19 11:26:27.630 EST: TFTP: Looking for CTLSEP001DA23EA1C6.tlv
005164: Oct 19 11:26:27.698 EST: TFTP: Looking for ITLSEP001DA23EA1C6.tlv
005165: Oct 19 11:26:27.770 EST: TFTP: Looking for ITLFile.tlv
005166: Oct 19 11:26:28.010 EST: TFTP: Looking for SEP001DA23EA1C6.cnf.xml
005167: Oct 19 11:26:28.010 EST: TFTP: Opened system:/its/vrf1/XMLDefault7942.cnf.xml, fd 3, size 1283 for process 429
005168: Oct 19 11:26:28.014 EST: TFTP: Finished system:/its/vrf1/XMLDefault7942.cnf.xml, time 00:00:00 for process 429
005169: Oct 19 11:26:30.190 EST: TFTP: Looking for English_United_States/mk-sccp.jar
005170: Oct 19 11:26:30.422 EST: TFTP: Looking for United_States/g3-tones.xml
