10-22-2012 07:52 AM - edited 03-16-2019 01:48 PM
Hello everybody!
I have a big issue with inbound calls on a UC540.
First of all here the relating configuration:
Translation Rules:
voice translation-rule 1
rule 1 /\(^.+\)/ /00\1/ type national national
rule 2 /\(^.+\)/ /000\1/ type international international
rule 3 /\(^.+\)/ /0\1/ type any subscriber
voice translation-rule 2
rule 1 /^79290/ /30/
rule 2 /^792925/ /20/
rule 3 /^792994/ /25/
rule 4 /^792995/ /27/
rule 5 /^7929/ //
voice translation-profile eingehend [incoming]
translate calling 1
translate called 2
Dial-Peers:
dial-peer voice 8 pots
description eingehende Telefonate
translation-profile incoming eingehend [incoming]
incoming called-number 79292.T
direct-inward-dial
dial-peer voice 7 pots
incoming called-number 79290
dial-peer voice 9 pots
incoming called-number 79294.T
direct-inward-dial
ISDN-Ports:
interface BRI0/1/0
no ip address
isdn switch-type basic-net3
isdn overlap-receiving T302 7000
isdn point-to-point-setup
isdn incoming-voice voice
isdn sending-complete
isdn static-tei 0
trunk-group ALL_BRI
interface BRI0/1/1
no ip address
isdn static-tei 0
trunk-group ALL_BRI
I hope this is enough for Troubleshooting.
Now, my problem is, when a call comes in from a certain number, the call is rejected because of a "incomplete number".
Here a debug example (Q931 and voice Dial-Peer inout) for a call, which is connected normally:
009452: Oct 22 13:17:02.212: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x01
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x2180, '368179xxx'
Plan:ISDN, Type:National
Calling Party Number i = 0x2183, '36818062xxx'
Called Party Number i = 0xC1, '792941'
Plan:ISDN, Type:Subscriber(local)
009453: Oct 22 13:17:02.216: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=368179xxx, Called Number=792941, Voice-Interface=0x87B3EF44,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
009454: Oct 22 13:17:02.216: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=9
009455: Oct 22 13:17:02.216: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
009456: Oct 22 13:17:02.216: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=368179xxx, Called Number=792941, Voice-Interface=0x0,
Peer Info Type=DIALPEER_INFO_FAX
009457: Oct 22 13:17:02.216: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=NO_MATCH(-1) After All Match Rules Attempt
009458: Oct 22 13:17:02.216: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
009459: Oct 22 13:17:02.216: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=41, Peer Info Type=DIALPEER_INFO_SPEECH
009460: Oct 22 13:17:02.216: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=41
009461: Oct 22 13:17:02.216: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Result=Success(0) after DP_MATCH_DEST
009462: Oct 22 13:17:02.216: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
009463: Oct 22 13:17:02.216: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=20010
009464: Oct 22 13:17:02.220: //-1/99F348E6825C/DPM/dpMatchPeersCore:
009465: Oct 22 13:17:02.220: //-1/99F348E6825C/DPM/dpMatchPeersCore:
009466: Oct 22 13:17:02.220: //-1/99F348E6825C/DPM/dpMatchPeersCore:
009467: Oct 22 13:17:02.220: //-1/99F348E6825C/DPM/dpMatchSafModulePlugin:
dialstring=41, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
009468: Oct 22 13:17:02.220: //-1/99F348E6825C/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
and so on
009519: Oct 22 13:17:02.244: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
009520: Oct 22 13:17:02.248: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0x81
Channel ID i = 0x89
Exclusive, B1
009521: Oct 22 13:17:02.264: ISDN BR0/1/0 Q931: TX -> ALERTING pd = 8 callref = 0x81
And here a debug example from a call, which is rejected:
008550: Oct 22 11:58:01.160: ISDN BR0/1/1 Q931: RX <- SETUP pd = 8 callref = 0x01
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Channel ID i = 0x89
Exclusive, B1
Progress Ind i = 0x8083 - Origination address is non-ISDN
Calling Party Number i = 0x2181, '3682464xxx'
Called Party Number i = 0xC1, '79292'
008551: Oct 22 11:58:01.164: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=3682464xxx, Called Number=79292, Voice-Interface=0x87B4EA40,
Timeout=FALSE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
008552: Oct 22 11:58:01.164: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=99
008553: Oct 22 11:58:01.164: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
008554: Oct 22 11:58:01.164: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=3682464xxx, Called Number=79292, Voice-Interface=0x0,
008555: Oct 22 11:58:01.164: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008556: Oct 22 11:58:01.164: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
008557: Oct 22 11:58:01.168: ISDN BR0/1/1 Q931: TX -> SETUP_ACK pd = 8 callref = 0x81
Channel ID i = 0x89
Exclusive, B1
008558: Oct 22 11:58:01.256: ISDN BR0/1/1 Q931: RX <- INFORMATION pd = 8 callref = 0x01
Called Party Number i = 0xC1, '0'
008559: Oct 22 11:58:01.260: //-1/9010D2728251/DPM/dpMatchPeersCore:
Calling Number=, Called Number=792920, Peer Info Type=DIALPEER_INFO_SPEECH
008560: Oct 22 11:58:01.260: //-1/9010D2728251/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=792920
008561: Oct 22 11:58:01.260: //-1/9010D2728251/DPM/dpMatchPeersCore:
No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
008562: Oct 22 11:58:01.260: //-1/9010D2728251/DPM/dpMatchSafModulePlugin:
dialstring=792920, saf_enabled=1, saf_dndb_lookup=0, dp_result=-1
008563: Oct 22 11:58:01.260: //-1/9010D2728251/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
008564: Oct 22 11:58:01.264: ISDN BR0/1/1 Q931: TX -> DISCONNECT pd = 8 callref = 0x81
Cause i = 0x809C - Invalid number format (incomplete number)
I am wondering about the divided called party number (here fat).
Can somebody help me please, because I don't know where to look to solve this issue!
Thanks a lot!
Matthias
Solved! Go to Solution.
10-26-2012 07:50 AM
so in dial peer put
destination-pattern 936818062633 (which 9 is the access code)
forward digits11
if you dont want to use access code and you want to dial only 33 then
destination-pattern 36818062633
forward digits11
10-22-2012 11:15 AM
This is normal overlap-receiving, in the first case they are calling 792941, in the second 792920 from a fixed line phone.
But since you have a translation rule for 79292, as soon that is received, the call is routet to '2'.
You need tro translate for the entire number, eg ^792920 to 20.
10-23-2012 12:39 AM
thanks for your answer.
Here another Logg snippet. It seems, that the UC is not "waiting" long enough.
016083: Oct 23 07:23:01.556: ISDN BR0/1/1 Q931: RX <- SETUP pd = 8 callref = 0x01
Standard = CCITT
Channel ID i = 0x8A
Exclusive, B2
Calling Party Number i = 0x2181, '3682464400'
Called Party Number i = 0xC1, '7929'
016084: Oct 23 07:23:01.556: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=3682464400, Called Number=7929, Voice-Interface=0x87B4EA40,
016085: Oct 23 07:23:01.556: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
016086: Oct 23 07:23:01.556: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
016087: Oct 23 07:23:01.556: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=3682464400, Called Number=7929, Voice-Interface=0x0,
016088: Oct 23 07:23:01.556: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
016089: Oct 23 07:23:01.556: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
016090: Oct 23 07:23:01.560: ISDN BR0/1/1 Q931: TX -> SETUP_ACK pd = 8 callref = 0x81
Channel ID i = 0x8A
Exclusive, B2
016091: Oct 23 07:23:01.560: //-1/4FF20FE7828C/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x88B67170; count=1
016092: Oct 23 07:23:01.560: //-1/4FF20FE7828C/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x887C75F4
016093: Oct 23 07:23:01.564: //-1/4FF20FE7828C/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x88B67170; count=1
016094: Oct 23 07:23:01.644: ISDN BR0/1/1 Q931: RX <- INFORMATION pd = 8 callref = 0x01
Called Party Number i = 0xC1, '2'
016095: Oct 23 07:23:01.648: //-1/4FF20FE7828C/DPM/dpMatchPeersCore:
Calling Number=, Called Number=79292, Peer Info Type=DIALPEER_INFO_SPEECH
016096: Oct 23 07:23:01.648: //-1/4FF20FE7828C/DPM/dpMatchPeersCore:
016097: Oct 23 07:23:01.648: //-1/4FF20FE7828C/DPM/dpMatchPeersCore:
016098: Oct 23 07:23:01.648: //-1/4FF20FE7828C/DPM/dpMatchSafModulePlugin:
dialstring=79292, saf_enabled=1, saf_dndb_lookup=0, dp_result=-1
016099: Oct 23 07:23:01.648: //-1/4FF20FE7828C/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
016100: Oct 23 07:23:01.652: ISDN BR0/1/1 Q931: TX -> DISCONNECT pd = 8 callref = 0x81
016101: Oct 23 07:23:01.664: ISDN BR0/1/1 Q931: RX <- INFORMATION pd = 8 callref = 0x01
016102: Oct 23 07:23:01.720: ISDN BR0/1/1 Q931: RX <- RELEASE pd = 8 callref = 0x01
016103: Oct 23 07:23:01.724: ISDN BR0/1/1 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x81
The last digit came after the UC disconnected the call. If it would "wait" longer, then the call should be connected. Or am I wrong?
Or should I configure another Dialpeer like this:
dial-peer voice 21 pots
incoming called-number 7929..T
direct-inward-dial
DrMxxxxx
10-23-2012 12:53 AM
Some additional information:
In the logs I see, that the call want to use the incoming dial peer 99.
This is this one:
dial-peer voice 99 pots
trunkgroup ALL_BRI
corlist outgoing call-national
description **CCA*Deutschland*Kurzwahl**
translation-profile outgoing KURZWAHL
preference 4
destination-pattern 3[0-9]
forward-digits all
no sip-register
This dialpeer is used for shortdials to another location, which has a numbering plan beginning with a 3.
Can there be an issue?
I deleted the preference, because the other dialpeers have also no preference.
Thanks a lot!
DrMxxxxx
10-23-2012 01:35 AM
Just create a pure dial peer pots for incoming calls with preference 0 and try
dial-peer voice 50 pots
incoming called-number .
direct-inward-dial
prefer 0
send the debug isdn q931 and the debug voip dialpeer
Note: Remove ALL the incoming-called number command from ALL the other dial peers
You need one for the pots and one for the voip..Nothing esle regarding incoming calls
chrysostomos
10-23-2012 02:42 AM
thanks for your help.
Here are the Debug outputs from a call, which is not working. The call came digit by digit and the UC took the Dialpeer 99, which is the wrong one.
021311: Oct 23 09:33:17.451: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x01
Standard = CCITT
Channel ID i = 0x89
Exclusive, B1
021312: Oct 23 09:33:17.451: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=3682464400, Called Number=7929, Voice-Interface=0x87B3EF44,
021313: Oct 23 09:33:17.455: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
021314: Oct 23 09:33:17.455: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
021315: Oct 23 09:33:17.455: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
021316: Oct 23 09:33:17.455: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
021317: Oct 23 09:33:17.455: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
021318: Oct 23 09:33:17.455: ISDN BR0/1/0 Q931: TX -> SETUP_ACK pd = 8 callref = 0x81
Channel ID i = 0x89
Exclusive, B1
021319: Oct 23 09:33:17.459: //-1/8295109A82AD/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x88B66988; count=1
021320: Oct 23 09:33:17.459: //-1/8295109A82AD/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x887C83D4
021321: Oct 23 09:33:17.459: //-1/8295109A82AD/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x88B66988; count=1
021322: Oct 23 09:33:17.539: ISDN BR0/1/0 Q931: RX <- INFORMATION pd = 8 callref = 0x01
021323: Oct 23 09:33:17.543: //-1/8295109A82AD/DPM/dpMatchPeersCore:
Calling Number=, Called Number=79290, Peer Info Type=DIALPEER_INFO_SPEECH
021324: Oct 23 09:33:17.543: //-1/8295109A82AD/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=79290
021325: Oct 23 09:33:17.543: //-1/8295109A82AD/DPM/dpMatchPeersCore:
021326: Oct 23 09:33:17.543: //-1/8295109A82AD/DPM/dpMatchSafModulePlugin:
dialstring=79290, saf_enabled=1, saf_dndb_lookup=0, dp_result=-1
021327: Oct 23 09:33:17.543: //-1/8295109A82AD/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
021328: Oct 23 09:33:17.547: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8 callref = 0x81
021329: Oct 23 09:33:17.619: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x01
021330: Oct 23 09:33:17.623: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x81
021331: Oct 23 09:33:17.623: //-1/8295109A82AD/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x88B66988; count=1
021332: Oct 23 09:33:17.623: //-1/8295109A82AD/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x887C83D4
021333: Oct 23 09:33:17.627: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=3[0-9], Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
021334: Oct 23 09:33:17.627: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
021335: Oct 23 09:33:17.627: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Why is the UC taking the Dialpeer 99 and not 50??
And when I delete the dialpeer 99, the short dials to the other location are not working any more.
Thanks guys!
DrMxxxxx
10-23-2012 03:07 AM
questions:
1) What is the called number that you dial?(the full number that you dial from the PSTN phone)
2) The dial peer 99 is only for outgoing calls and not incoming,This is strange
3) Did you remove the incoming-called number from the other dial peers?
4) Preference 0 means it has highter priority from other that has preference 1
If you dont have preferce then it takes the default(preference 0)
5) What is the extension number that you try to (reach)
A)Can you check the above and if is possible reload the router
10-23-2012 06:13 AM
Hi Chrys,
here my replies:
1) The called number was 03681792920 --> the calling number was 03682... and there was the mistake. Because Dialpeer 99 was chosen from the system.
2) Yeah. That's my fault. I deleted this Dialpeer completely from the config. Now it is working again.
3) Yes
4) Now I have no preference on any Dialpeer.
5) 20
As mentioned above the System took the dialpeer 99 because of the calling number (which began with a 3) and tried now to connect the call. I deleted the Dialpeer and have now for incoming calls only the Dialpeer 50 (like some posts before) and now it is working again.
Thank's a lot!
DrMxxxxx
10-23-2012 06:29 AM
Glad to hear that
Pls rate useful posts
10-26-2012 04:26 AM
now I have another question. Since I have deleted the Dialpeer for the short dials, the short dials doesn't work any more (surprise ).
But I want to offer the customers this feature on their phones and I don't know how to implement it. Can you help me? It should be working like the dialpeer 99 mentioned above, so when they dial the 3x they should reach another phone in another location. The call will be routed via ISDN, because there is no LAN connectivity between the two locations.
Here the config before I deleted the dialpeer 99:
voice translation-rule 1113
rule 1 /^\(3.\)/ /368180626\1/ type any national
voice translation-profile KURZWAHL
translate called 1113
trunkgroup ALL_BRI
preference 4
forward-digits all
no sip-register
Thanks in advance!
Matthias
10-26-2012 04:59 AM
Lerts start from the begin
With the below translation what do you want to do?
You want to dial for example 33 and then to be translated to 36818062633
can you write me your thought for that translation rule?
Second the destination number in dial peer 99 is 2 digits?With the translation that you provided does not
it should be more..How many digits (caled) number you wanrt to send each time
Third the destination is a pstn number or is a voip number
trunkgroup ALL_BRI
preference 4
forward-digits all
no sip-register
10-26-2012 07:05 AM
Ok, I have to say, that I'm a beginner in Dialpeers and their configuration.
Yes, your example is right. When the user calls the 33 the System should call the PSTN-Number 36818062633 and the call should be routed over ISDN to the external location.
So, am I right, that I have to configure the whole number as the destination-pattern in the dialpeer? The number has normally the same length.
Thanks a lot!
Matthias
10-26-2012 07:50 AM
so in dial peer put
forward digits11
forward digits11
11-02-2012 04:58 AM
this Problem gets really annoying!
Now I configured the Dialpeer as you mentioned, but when now someone is dialing the shortdial, e.g. 32, the system says it has no dialpeer for this calling number.
Here the config:
trunkgroup ALL_BRI
destination-pattern 3681806263[0-9]
forward-digits 11
no sip-register
When I check the translation rule, it translate the number correctly.
Thanks a lot!
Matthias
11-02-2012 05:05 AM
Remove the translation from the dial peer
trunkgroup ALL_BRI
destination-pattern 3.
forward-digits 11
no sip-register
prefix 368180626
