07-26-2019 01:58 PM
I have a particular scenario that is less than ideal. Basically a user dials a DID we own, its handed to our SIP Gateway and the handed to CUCM where it gets sent to a CTI route point that then forwards to an external number.However there is no ringback from either the CTI or the external number but if I call internal to the CTI i do get ringback. I have identified the traces and i do not see SDP 180 messages coming through, which I believe may be by design. I have listed the traces below from the particular call. Thank you in advanced for any help!
07-26-2019 05:06 PM
Your 180 RINGING message is not being sent from the CUBE.
I found this helpful to explain it:
In a similar discussion, they mention a workaround to disable early media. Is your CUCM sending 180 ringing back to the CUBE?
07-29-2019 06:49 AM - edited 07-29-2019 08:27 AM
Thank you very much for the response, Jonathan! Unfortunately it is not. It appears that the 180 ringing with SDP maybe getting converted to 183.
