06-17-2012 06:48 AM - edited 03-16-2019 11:42 AM
I was wondering if there was something special reqiured to register mobile Jabber clients to the CUCMBE 3K, all the Doco I have read thus far seems to indicate that it is supported so I thought I would give it a shot as I have a spare enhanced user license. I have uploaded the cop.sgn for andoid jabber, not sure if that was required but seemed to intall without any issues.
When registering it just tells me to check my settings. (Extremely usefull error message)
Device ID is set to CSFTEST when configuring the phone
Is there something I am am missing
BE-3000 version 8.6.3.10000-12
Android Jabber latest version.
Any help is much appreciated
06-17-2012 08:47 PM
Have you read below admin guide
Ronak patel
Rate helpful posts.
07-02-2012 02:05 AM
Hi Ronak,
It seems the jabber for android is supported with 8.6.4. Have you try to deploy it in 8.6.3 ?
When I was testing the 8.6.4 version I found the config menu , But registering failed . Did anyone succed ?
