Jabber via VPN issue!!!
Mohamed OTHMAN
I connected cisco jabber over VPN (3G) to my UC520
I can dial from the Jabber but when try to call from a phone I got ''unknown number'' (busy)
10 Replies 10
Hi Mohammed,
Could you please be more specific
where are you calling?
Is it internal or outside calls that are failing?
(when connected over wireless directly to our network, I have no problems I can call in two ways)
But When connected over VPN to my uc560 and I try to call the IPhone  from any ip-phone I got unknown number,
and from the IPHONE I can call any extension!
do u need the configuration of the uc?
(I'm using an srp527)
this is a debug when I try to call it:
UC560#
001198: Jun 25 17:26:50.217: //987/40A474B787CB/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x89297D48
State of The Call        : STATE_DEAD
TCP Sockets Used         : YES
Calling Number           : 201
Called Number            : 125
Source IP Address (Sig  ): 192.168.0.130
Destn SIP Req Addr:Port  : 192.168.50.1:50087
Destn SIP Resp Addr:Port : 192.168.50.1:50087
Destination Name         : 192.168.50.1
001199: Jun 25 17:26:50.217: //987/40A474B787CB/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 192.168.0.130
Source IP Port    (Media): 18020
Destn  IP Address (Media):  -
Destn  IP Port    (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
001200: Jun 25 17:26:50.217: //987/40A474B787CB/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 38
Disconnect Cause (SIP)   : 503
001201: Jun 25 17:26:50.721: //988/40A474B787CB/SIP/Call/sipSPICallInfo:
TCP Sockets Used         : NO
Called Number            : 125
Destn SIP Req Addr:Port  : 192.168.0.254:5060
Destn SIP Resp Addr:Port : 192.168.0.254:5060
Destination Name         : 192.168.0.254
001202: Jun 25 17:26:50.721: //988/40A474B787CB/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 19278
001203: Jun 25 17:26:50.721: //988/40A474B787CB/SIP/Call/sipSPICallInfo:
Disconnect Cause (SIP)   : 200   (I got 503 too)
Hi Mohamed,
It would give me a better understanding if you uploaded your configuration
Just to clear things up :
Wireless
SPR500 ---> Cisco IP Phone(Type?)---> UC560 ---> Cisco IP Phone
Working
VPN
Cisco IP Phone --->UC560 --> SPR500 ---> Cisco IP Phone(Type?)
Not Working
Is this a one way issue when connected over VPN?
And also use the following debug
debug ccsip messages
Whats the extension of the IP Phone connected to SPR500?
Whats the extension you are trying to call?
and upload a debug of both when In wireless and VPN
Message was edited by: Zekeria Sammantar
this is the conf
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
  ipv4 192.168.0.80 255.255.255.255
  ipv4 192.168.50.0 255.255.255.0
  ipv4 192.168.0.79 255.255.255.255
  ipv4 192.168.50.1 255.255.255.255
  ipv4 192.168.0.73 255.255.255.255
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
  bind control source-interface Vlan1
  bind media source-interface Vlan1
  registrar server
voice register global
mode cme
source-address 192.168.0.25 port 5060
max-dn 20
max-pool 10
load 3911 SIP3951.8-1-2
authenticate register
authenticate realm omega.com.tn
timezone 28
tftp-path flash:
create profile sync 0912118504123498
voice register dn  1
number 125
allow watch
name cisco
label 125
voice register pool  1
registration-timer max 720 min 660
id mac CC08.E0CB.60FE
type CiscoMobile-iOS
number 1 dn 1
dtmf-relay rtp-nte
username cisco password cisco123
codec g711ulaw
interface Vlan1
description $FW_INSIDE$
ip address 192.168.0.25 255.255.255.0
ip virtual-reassembly in
interface Vlan100
ip address 192.168.11.1 255.255.255.0
sip-ua
DEBUG FROM WIRELESS
C560#debug voice ?
  aaa                 VoIP AAA
  ais                 AIS (Application Information System)
  application         Application Framework library debugging
  avlist              avlist debugs
  call                Voice call debugging
  ccapi               Call Control API
  confmsp             Conference Media Service Provider
  data                Data dump debug command
  dcapi               Device Control API
  dialpeer            dialpeer debugging
  dsm                 DSP Stream Manager Debugs
  dsmp                Distributed Streams Media Processor
  dsp                 DSP
  dspapi              Generic DSP API
  dump-file-acct      File Accounting
  eddri               eddri debug
  em-profile          Debug extension mobility profile commands
  enum                ENUM information
  event-log           Event logging
  fileacct            VoIP FILE ACCT
  hpi                 HPI (54x) DSP messages
  ipipgw              IP-to-IP gateway
  iptrust             Voip ip address trust debug
--More--                             lpcor               voip lpcor debugging
  mlpp                voip mlpp debugging
  persistent-storage  Persistent Storage Debugs
  profile             debug voip profile
  rawmsg              Raw Message
  register            voice-register debug information
  rtcp                Enable VOIP RTCP debugging trace
  rtp                 Enable VOIP RTP debugging trace
  settlement          Settlement debugging
  source-group        Source-group debugging
  srtcp               Enable VOIP SRTCP debugging trace
  srtp                Enable VOIP IOS SRTP debugging trace
  statistics          Voice Statistics
  swmtpmsp            Software MTP Media Service Provider
  translation         Debug translation rules
  tsp                 Telephony Service information
  uri                 Debug Voice URI
  vpn                 Voice service VPN debugging
  vtsp                Voice Telephony Call Control information
  xcodemsp            Transcoding Media Service Provider
UC560#debug voice                       voice ?
  aaa                 VoIP AAA
  dsp                 DSP
  eddri               eddri debug
  rawmsg              Raw Message
  uri                 Debug Voice URI
UC560#debug voice                                            sh sip conn
UC560#sh sip connections
% Incomplete command.
UC560#sh sip connections ?
  tcp  Display TCP Connection Information
  udp  Display UDP Connection Information
UC560#sh sip connections tcp
UC560#sh sip connections tcp ?
  brief   Show summary of connections
  detail  Show detail connection information
  tls     Display TLS Connection Information
UC560#sh sip connections tcp de
UC560#sh sip connections tcp detail
Total active connections      : 2
No. of send failures          : 2
No. of remote closures        : 636
No. of conn. failures         : 68
No. of inactive conn. ageouts : 12
Max. tcp send msg queue size of 2, recorded for 192.168.0.254:60663
---------Printing Detailed Connection Report---------
Note:
** Tuples with no matching socket entry
    - Do 'clear sip conn t ipv4::'
      to overcome this error condition
++ Tuples with mismatched address/port entry
    - Do 'clear sip conn t ipv4:: id '
Remote-Agent:192.168.50.1, Connections-Count:0
Remote-Agent:192.168.0.254, Connections-Count:2
  Remote-Port Conn-Id Conn-State  WriteQ-Size Local-Address
        63820       4 Established           0 192.168.0.130
        63723       3 Established           0 192.168.0.130
--More--
-------------- SIP Transport Layer Listen Sockets ---------------
--More--                             Conn-Id               Local-Address
--More--                              2            [192.168.0.130]:5060
UC560#
UC560#
UC560#
UC560#
UC560#wr
Building configuration...
Compressed configuration from 28318 bytes to 13332 bytes[OK]
UC560#
OmegaES-VG#
OmegaES-VG#
OmegaES-VG#
OmegaES-VG#
OmegaES-VG#
OmegaES-VG#
036304: Jun 28 11:38:49.875: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId 9AA6FA57DF1511E29A5CB268EDC2EDCD, SetupTime 11:37:46.365 CET Fri Jun 28 2013, PeerAddress 125, PeerSubAddress , DisconnectCause 10  , DisconnectText normal call clearing (16), ConnectTime 11:38:49.875 CET Fri Jun 28 2013, DisconnectTime 11:38:49.875 CET Fri Jun 28 2013, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
036305: Jun 28 11:38:49.875: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:06/28/2013 11:37:46.359,cgn:103,cdn:125,frs:0,fid:9827,fcid:9AA6FA57DF1511E29A5CB268EDC2EDCD,legID:7798,bguid:9AA6FA57DF1511E29A5CB268EDC2EDCD
036306: Jun 28 10:38:49.875: VOIP_CALL_STATISTICS:DSP/TX: PK=0, SG=0, NS=0, DU=0, VO=0
DSP/RX: PK=0, SG=0, CF=0, RX=0, VO=0, BS=0, BP=0, LP=0, EP=0
DSP/PD: CU=0, MI=0, MA=0, CO=0, IJ=0.0000
DSP/PE: PC=0, IC=0, SC=0, RM=0, BO=0, EE=0
DSP/LE: TP=0, TX=0, RP=0, RM=0, BN=0, ER=0, AC=0
DSP/ER: RD=0, TD=0, RC=0, TC=0
DSP/IC: IC=0
036307: Jun 28 10:38:52.015: //30626/C1CBBB649A71/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:125@192.168.0.73:65121 SIP/2.0
Via: SIP/2.0/TCP 192.168.0.25:5060;branch=z9hG4bK5FE18E6
Remote-Party-ID: "Omega Hotline" <103>;party=calling;screen=no;privacy=off
To: <125>
Date: Fri, 28 Jun 2013 10:38:52 GMT
Call-ID: C234B690-DF1511E2-9A76B268-EDC2EDCD@192.168.0.25
Supported: 100rel,timer,resource-priority,replaces
Min-SE:  1800
Cisco-Guid: 3251354468-3742700002-2591142504-3988975053
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1372415932
Contact: <103>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 271
v=0
o=CiscoSystemsSIP-GW-UserAgent 6840 4250 IN IP4 192.168.0.25
s=SIP Call
c=IN IP4 192.168.0.25
t=0 0
m=audio 18438 RTP/AVP 0 101 19
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
036308: Jun 28 10:38:52.135: //30626/C1CBBB649A71/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <125>
Date: Fri, 28 Jun 2013 10:37:14 GMT
CSeq: 101 INVITE
Server: Cisco-SIPIPCommunicator/9.2.1
Contact: <125>
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE,INFO
Supported: replaces,join,sdp-anat,norefersub,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-5.2.0
Allow-Events: kpml,dialog
Content-Length: 0
Recv-Info: conference
Recv-Info: x-cisco-conference
036309: Jun 28 10:38:52.235: //30626/C1CBBB649A71/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <125>;tag=00000000000001a93860ca5c-5a857aee
CSeq: 101 INVITE
Contact: <125>
Remote-Party-ID: "cisco" <125>;party=called;id-type=subscriber;privacy=off;screen=yes
Content-Length: 0
036310: Jun 28 11:38:52.839: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId C1CBBB64DF1511E29A71B268EDC2EDCD, SetupTime 11:38:51.319 CET Fri Jun 28 2013, PeerAddress 103, PeerSubAddress , DisconnectCause 10  , DisconnectText normal call clearing (16), ConnectTime 11:38:52.829 CET Fri Jun 28 2013, DisconnectTime 11:38:52.829 CET Fri Jun 28 2013, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
036311: Jun 28 11:38:52.839: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:06/28/2013 11:38:51.323,cgn:103,cdn:,frs:0,fid:9832,fcid:C1CBBB64DF1511E29A71B268EDC2EDCD,legID:77A1,bguid:C1CBBB64DF1511E29A71B268EDC2EDCD
036312: Jun 28 10:38:52.839: //30626/C1CBBB649A71/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:125@192.168.0.73:65121 SIP/2.0
To: <125>
CSeq: 101 CANCEL
Max-Forwards: 70
Reason: Q.850;cause=16
Content-Length: 0
036313: Jun 28 10:38:52.859: //30626/C1CBBB649A71/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Date: Fri, 28 Jun 2013 10:37:15 GMT
CSeq: 101 CANCEL
Content-Length: 0
036314: Jun 28 11:38:52.859: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId C1CBBB64DF1511E29A71B268EDC2EDCD, SetupTime 11:38:52.009 CET Fri Jun 28 2013, PeerAddress 125, PeerSubAddress , DisconnectCause 10  , DisconnectText normal call clearing (16), ConnectTime 11:38:52.859 CET Fri Jun 28 2013, DisconnectTime 11:38:52.859 CET Fri Jun 28 2013, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
036315: Jun 28 11:38:52.863: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:06/28/2013 11:38:52.003,cgn:103,cdn:125,frs:0,fid:9833,fcid:C1CBBB64DF1511E29A71B268EDC2EDCD,legID:77A2,bguid:C1CBBB64DF1511E29A71B268EDC2EDCD
036316: Jun 28 10:38:52.863: VOIP_CALL_STATISTICS:DSP/TX: PK=0, SG=0, NS=0, DU=0, VO=0
DSP/IC: IC=0
036317: Jun 28 10:38:53.119: //30626/C1CBBB649A71/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 487 Request Cancelled
CSeq: 101 INVITE
Contact: <125>
Content-Length: 0
036318: Jun 28 10:38:53.119: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:125@192.168.0.73:65121 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
036319: Jun 28 10:38:56.039: //30628/C42C40539A77/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/TCP 192.168.0.25:5060;branch=z9hG4bK5FFF11
To: <125>
Date: Fri, 28 Jun 2013 10:38:56 GMT
Call-ID: C49ABA18-DF1511E2-9A7CB268-EDC2EDCD@192.168.0.25
Min-SE:  1800
Cisco-Guid: 3291234387-3742700002-2591535720-3988975053
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1372415936
Contact: <103>
Expires: 180
Content-Length: 271
v=0
o=CiscoSystemsSIP-GW-UserAgent 4756 5596 IN IP4 192.168.0.25
s=SIP Call
t=0 0
m=audio 17388 RTP/AVP 0 101 19
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
036320: Jun 28 10:38:56.099: //30628/C42C40539A77/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <125>
Date: Fri, 28 Jun 2013 10:37:18 GMT
CSeq: 101 INVITE
Contact: <125>
Content-Length: 0
036321: Jun 28 10:38:56.407: //30628/C42C40539A77/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <125>;tag=00000000000001aa245ed644-4e451d03
CSeq: 101 INVITE
Contact: <125>
Content-Length: 0
036322: Jun 28 11:39:26.803: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId C42C4053DF1511E29A77B268EDC2EDCD, SetupTime 11:38:55.313 CET Fri Jun 28 2013, PeerAddress 103, PeerSubAddress , DisconnectCause 10  , DisconnectText normal call clearing (16), ConnectTime 11:39:26.803 CET Fri Jun 28 2013, DisconnectTime 11:39:26.803 CET Fri Jun 28 2013, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
036323: Jun 28 11:39:26.803: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:06/28/2013 11:38:55.311,cgn:103,cdn:,frs:0,fid:9834,fcid:C42C4053DF1511E29A77B268EDC2EDCD,legID:77A3,bguid:C42C4053DF1511E29A77B268EDC2EDCD
036324: Jun 28 10:39:26.803: //30628/C42C40539A77/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <125>
CSeq: 101 CANCEL
Max-Forwards: 70
Timestamp: 1372415966
Content-Length: 0
036325: Jun 28 10:39:26.911: //30628/C42C40539A77/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Date: Fri, 28 Jun 2013 10:37:49 GMT
CSeq: 101 CANCEL
Content-Length: 0
036326: Jun 28 11:39:26.911: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId C42C4053DF1511E29A77B268EDC2EDCD, SetupTime 11:38:56.031 CET Fri Jun 28 2013, PeerAddress 125, PeerSubAddress , DisconnectCause 10  , DisconnectText normal call clearing (16), ConnectTime 11:39:26.911 CET Fri Jun 28 2013, DisconnectTime 11:39:26.911 CET Fri Jun 28 2013, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
036327: Jun 28 11:39:26.911: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:06/28/2013 11:38:56.027,cgn:103,cdn:125,frs:0,fid:9835,fcid:C42C4053DF1511E29A77B268EDC2EDCD,legID:77A4,bguid:C42C4053DF1511E29A77B268EDC2EDCD
036328: Jun 28 10:39:26.911: VOIP_CALL_STATISTICS:DSP/TX: PK=0, SG=0, NS=0, DU=0, VO=0
DSP/IC: IC=0
036329: Jun 28 10:39:27.215: //30628/C42C40539A77/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 101 INVITE
Contact: <125>
Content-Length: 0
036330: Jun 28 10:39:27.219: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
DEBUG FROM VPN CONNECTION
36595: Jun 28 11:39:49.791: //30873/453E87CF9BD7/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:125@192.168.50.50:64683 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.25:5060;branch=z9hG4bK6021C03
To: <125>
Date: Fri, 28 Jun 2013 11:39:49 GMT
Call-ID: 4668FE7F-DF1E11E2-9BDCB268-EDC2EDCD@192.168.0.25
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 1161725903-3743289826-2614604392-3988975053
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1372419589
Contact: <103>
Expires: 180
Content-Length: 271
v=0
o=CiscoSystemsSIP-GW-UserAgent 2150 8183 IN IP4 192.168.0.25
s=SIP Call
t=0 0
m=audio 18096 RTP/AVP 0 101 19
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
036596: Jun 28 11:39:50.291: //30873/453E87CF9BD7/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <125>
Date: Fri, 28 Jun 2013 11:39:50 GMT
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1372419590
Contact: <103>
Expires: 180
Content-Length: 271
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
036597: Jun 28 11:39:51.291: //30873/453E87CF9BD7/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <125>
Date: Fri, 28 Jun 2013 11:39:51 GMT
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1372419591
Contact: <103>
Expires: 180
Content-Length: 271
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
036598: Jun 28 11:39:53.291: //30873/453E87CF9BD7/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <125>
Date: Fri, 28 Jun 2013 11:39:53 GMT
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1372419593
Contact: <103>
Expires: 180
Content-Length: 271
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
036599: Jun 28 11:39:57.291: //30873/453E87CF9BD7/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <125>
Date: Fri, 28 Jun 2013 11:39:57 GMT
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1372419597
Contact: <103>
Expires: 180
Content-Length: 271
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
036600: Jun 28 11:40:05.291: //30873/453E87CF9BD7/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <125>
Date: Fri, 28 Jun 2013 11:40:05 GMT
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1372419605
Contact: <103>
Expires: 180
Content-Length: 271
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
036601: Jun 28 12:40:16.255: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 453E87CFDF1E11E29BD7B268EDC2EDCD, SetupTime 12:39:47.835 CET Fri Jun 28 2013, PeerAddress 103, PeerSubAddress , DisconnectCause 10  , DisconnectText normal call clearing (16), ConnectTime 12:40:16.255 CET Fri Jun 28 2013, DisconnectTime 12:40:16.255 CET Fri Jun 28 2013, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
036602: Jun 28 12:40:16.259: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:06/28/2013 12:39:47.831,cgn:103,cdn:,frs:0,fid:9951,fcid:453E87CFDF1E11E29BD7B268EDC2EDCD,legID:7898,bguid:453E87CFDF1E11E29BD7B268EDC2EDCD
036603: Jun 28 11:40:21.291: //30873/453E87CF9BD7/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <125>
Date: Fri, 28 Jun 2013 11:40:21 GMT
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1372419621
Contact: <103>
Expires: 180
Content-Length: 271
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
OmegaES-VG#
OmegaES-VG#
036604: Jun 28 12:40:53.291: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId 453E87CFDF1E11E29BD7B268EDC2EDCD, SetupTime 12:39:49.781 CET Fri Jun 28 2013, PeerAddress 125, PeerSubAddress , DisconnectCause 10  , DisconnectText normal call clearing (16), ConnectTime 12:40:53.291 CET Fri Jun 28 2013, DisconnectTime 12:40:53.291 CET Fri Jun 28 2013, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
036605: Jun 28 12:40:53.291: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:06/28/2013 12:39:49.779,cgn:103,cdn:125,frs:0,fid:9952,fcid:453E87CFDF1E11E29BD7B268EDC2EDCD,legID:7899,bguid:453E87CFDF1E11E29BD7B268EDC2EDCD
OmegaES-VG#
OmegaES-VG#
036606: Jun 28 11:40:53.291: VOIP_CALL_STATISTICS:DSP/TX: PK=0, SG=0, NS=0, DU=0, VO=0
DSP/IC: IC=0
036607: Jun 28 11:41:05.235: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REFER sip:192.168.0.25 SIP/2.0
Via: SIP/2.0/TCP 192.168.50.1:65377;branch=z9hG4bK5fc5f170
From: <000000000000>;tag=000000000000000c07f98637-0eda88f8
To: <192.168.0.25>
Call-ID: 00000000-00000008-2d565966-00074ecb@192.168.50.1
Date: Fri, 28 Jun 2013 11:39:27 GMT
CSeq: 1000 REFER
User-Agent: Cisco-SIPIPCommunicator/9.2.1
Expires: 10
Max-Forwards: 0
Contact: <000000000000>
Require: norefersub
Referred-By: <000000000000>
Refer-To: cid:3c6e212f@192.168.50.1
Content-Id: <3c6e212f@192.168.50.1>
Content-Length: 1297
Content-Type: application/x-cisco-alarm+xml
SEPCC08E0CB60FE
192.168.50.1 / 0
0.0.0.0
SIPIPCommunicator
65353
1372419506
14
Sent:REGISTER sip:192.168.0.25 SIP/2.0  Cseq:105 REGISTER CallId:00000000-00000003-7e523918-48229772@192.168.50.1
036608: Jun 28 11:41:05.239: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 400 Bad Request
Via: SIP/2.0/TCP 192.168.50.1:65377;branch=z9hG4bK5fc5f170;received=192.168.0.254
To: <192.168.0.25>;tag=5B6B4800-1052
Date: Fri, 28 Jun 2013 11:41:05 GMT
CSeq: 1000 REFER
Content-Length: 0
Contact: <192.168.0.25:5060>
036609: Jun 28 11:41:05.315: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 192.168.50.1:65377;branch=z9hG4bK5fd66d4a
To: <125>
Call-ID: 00000000-00000005-6244b3a7-0c6ecb58@192.168.50.1
Max-Forwards: 70
CSeq: 106 REGISTER
Contact: <125>;+sip.instance="";+sip.instance="";+u.sip!devicename.ccm.cisco.com="SEPCC08E0CB60FE";+u.sip!model.ccm.cisco.com="30016"
Reason: SIP;cause=200;text="cisco-alarm:25 Name=SEPCC08E0CB60FE ActiveLoad= InactiveLoad= Last=initialized"
Expires: 3600
Content-Type: multipart/mixed; boundary=uniqueBoundary
Mime-Version: 1.0
Content-Length: 566
--uniqueBoundary
Content-Type: application/x-cisco-remotecc-request+xml
Content-Disposition: session;handling=optional
--uniqueBoundary
--uniqueBoundary--
036610: Jun 28 11:41:05.319: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/TCP 192.168.50.1:65377;branch=z9hG4bK5fd66d4a;received=192.168.0.254
To: <125>
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 106 REGISTER
Content-Length: 0
036611: Jun 28 11:41:05.515: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 192.168.50.1:65377;branch=z9hG4bK393c891f
From: <000000000000>;tag=000000000000000e76a1466d-5616daf3
To: <192.168.0.25>
Call-ID: 00000000-00000009-7680b3ac-7b941dfb@192.168.50.1
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 0
Require: norefersub
Refer-To: cid:354e6f94@192.168.50.1
Content-Id: <354e6f94@192.168.50.1>
Content-Length: 1303
SEPCC08E0CB60FE
10.225.19.201 / 0
0.0.0.0
SIPIPCommunicator
4294967295
1372419564
14
036612: Jun 28 11:41:05.519: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 401 Unauthorized
To: <125>;tag=5B6B484C-1411
CSeq: 106 REGISTER
WWW-Authenticate: Digest realm="omega.com.tn",nonce="05152EE209245408",algorithm=MD5,qop="auth"
Content-Length: 0
036613: Jun 28 11:41:05.519: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/TCP 192.168.50.1:65377;branch=z9hG4bK393c891f;received=192.168.0.254
To: <192.168.0.25>;tag=5B6B4918-2613
CSeq: 1000 REFER
Content-Length: 0
036614: Jun 28 11:41:05.787: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 192.168.50.1:65377;branch=z9hG4bK00d997f5
To: <125>
Max-Forwards: 70
Date: Fri, 28 Jun 2013 11:39:28 GMT
CSeq: 107 REGISTER
Authorization: Digest username="cisco",realm="omega.com.tn",uri="sip:192.168.0.25",response="f65a89c19ae65b6f6209d15a24a643f4",nonce="05152EE209245408",cnonce="307f78e3",qop=auth,nc=00000001,algorithm=MD5
Expires: 3600
Mime-Version: 1.0
Content-Length: 566
--uniqueBoundary
--uniqueBoundary
--uniqueBoundary--
036615: Jun 28 11:41:05.799: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/TCP 192.168.50.1:65377;branch=z9hG4bK00d997f5;received=192.168.0.254
To: <125>
CSeq: 107 REGISTER
Content-Length: 0
036616: Jun 28 11:41:05.807: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <125>;tag=5B6B4A28-FE5
CSeq: 107 REGISTER
Supported: X-cisco-cme-sis-1.0.0
Supported: X-cisco-srtp-fallback
Contact: <125>;expires=720;x-cisco-newreg
Expires:  720
Content-Type: application/x-cisco-remotecc-response+xml
Content-Length: 323
200
036617: Jun 28 11:41:09.807: //30879/7531ECD99BE3/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.0.25:5060;branch=z9hG4bK6051779
To: <125>
Date: Fri, 28 Jun 2013 11:41:09 GMT
Call-ID: 761B1347-DF1E11E2-9BE8B268-EDC2EDCD@192.168.0.25
Min-SE:  1800
Cisco-Guid: 1966206169-3743289826-2615390824-3988975053
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1372419669
Contact: <103>
Expires: 180
Content-Length: 271
v=0
o=CiscoSystemsSIP-GW-UserAgent 7793 9826 IN IP4 192.168.0.25
s=SIP Call
t=0 0
m=audio 17672 RTP/AVP 0 101 19
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
036618: Jun 28 11:41:10.303: //30879/7531ECD99BE3/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <125>
Date: Fri, 28 Jun 2013 11:41:10 GMT
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1372419670
Contact: <103>
Expires: 180
Content-Length: 271
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
036619: Jun 28 11:41:11.303: //30879/7531ECD99BE3/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <125>
Date: Fri, 28 Jun 2013 11:41:11 GMT
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1372419671
Contact: <103>
Expires: 180
Content-Length: 271
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
036620: Jun 28 11:41:13.303: //30879/7531ECD99BE3/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <125>
Date: Fri, 28 Jun 2013 11:41:13 GMT
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1372419673
Contact: <103>
Expires: 180
Content-Length: 271
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
036621: Jun 28 11:41:17.303: //30879/7531ECD99BE3/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <125>
Date: Fri, 28 Jun 2013 11:41:17 GMT
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1372419677
Contact: <103>
Expires: 180
Content-Length: 271
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
036622: Jun 28 11:41:25.303: //30879/7531ECD99BE3/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <125>
Date: Fri, 28 Jun 2013 11:41:25 GMT
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1372419685
Contact: <103>
Expires: 180
Content-Length: 271
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
036623: Jun 28 12:41:28.835: %PARSER-5-CFGLOG_LOGGEDCMD: User:vty17  logged command:0vty17192.168.0.79vty172013-06-28T11:41:28.831Zvoice register global
036624: Jun 28 12:41:39.399: %PARSER-5-CFGLOG_LOGGEDCMD: User:vty17  logged command:0vty17192.168.0.79vty172013-06-28T11:41:39.399Zvoice register global no outbound-proxy
036625: Jun 28 11:41:41.303: //30879/7531ECD99BE3/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <125>
Date: Fri, 28 Jun 2013 11:41:41 GMT
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1372419701
Contact: <103>
Expires: 180
Content-Length: 271
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
036626: Jun 28 12:41:41.315: %PARSER-5-CFGLOG_LOGGEDCMD: User:vty17  logged command:0vty17192.168.0.79vty172013-06-28T11:41:41.315Zvoice register global exit
036627: Jun 28 12:41:43.779: %SYS-5-CONFIG_I: Configured from console by vty17 (192.168.0.79)
036628: Jun 28 12:41:49.359: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 7531ECD9DF1E11E29BE3B268EDC2EDCD, SetupTime 12:41:08.279 CET Fri Jun 28 2013, PeerAddress 103, PeerSubAddress , DisconnectCause 10  , DisconnectText normal call clearing (16), ConnectTime 12:41:49.349 CET Fri Jun 28 2013, DisconnectTime 12:41:49.349 CET Fri Jun 28 2013, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
036629: Jun 28 12:41:49.359: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:06/28/2013 12:41:08.275,cgn:103,cdn:,frs:0,fid:9953,fcid:7531ECD9DF1E11E29BE3B268EDC2EDCD,legID:789E,bguid:7531ECD9DF1E11E29BE3B268EDC2EDCD
Your problem is unclear, but I think you are trying to use Cisco Jabber for Iphone to receive calls. You say it works over wifi, but doesnt work over the mobile data network right?
The SIP trace above just shows that the there is a repeated SIP Invite to the endpoint, so its either being blocked or the Iphone isnt setup correctly.
Make sure you are doing this:
Q.
Can I connect to Cisco Jabber over the mobile data network?
A.
Connectivity over the mobile data network is disabled by default, but you can allow Cisco Jabber  to connect using the mobile data network. However, because voice  quality over a mobile data network varies depending on the quality of  your network connection, Cisco does not provide support to troubleshoot  mobile data network connectivity issues. If you experience difficulties  with mobile data network connectivity, turn this setting off.
  1. Tap Settings > Internet Calling.
  2. Turn Connect Over Mobile Data Network on.
I have good connection in my network, the Jabber is working finn e when directly connected to my network, but the problem is over VPN, from the Jabber I can call other extension but I can't receive calls
I removed the srp, I put the uc directly connected to the internet & I configured the VPN it works!
Dear Mohammed,
This is info I could gather from this config
Jabber IOS number = 125
VPN(3G-SPR57 to UC560): 192.168.50.50
WIRELESS: 192.168.0.73
And also make sure thats ip address of the jabber
from ip-phone to jabber(VPN)  ----> Reject
from jabber(vpn) to ip-phone ---> Accept( "I can dial from the Jabber but when try to call from a phone I got ''unknown number'' (busy))
Post the configuration for extenstion 103
Also post the following command output
Show ip inter br
Please make sure you attach any output from the cli for ease of reading
If possible upload the log files from jabber to verify registration.
You can follow these steps:
http://www.cisco.com/en/US/docs/voice_ip_comm/jabber/iPhone/9.0/JABI_BK_J29330BB_00_jabber-for-iphone-admin-guide_chapter_0100.html#JABI_TK_O3E5617C_00
Hi Zekeria,
Yesterday I removed the SRP, I configured the uc to take he's place & I configured the VPN on it too!
And evrything is working fine, I mean calls in both directions!
Maybe the problem is on the srp?
because when I maide sh dial-peer voice, I found that the uc created one to send calls to 192.168.50.50
Hi Mohamed,
What type of dial-peer, post the config to further analyze the issue.
Please rate replies and mark question as "answered" if applicable.
Best Regards,
Zekeria.
this is a sh dial-peer voice summary:
20032  pots  up   up             A000$              1
50/0/40
20033  pots  up   up             A000$              2
50/0/41
20034  pots  up   up             3000$              1
50/0/42
20035  pots  up   up             3000$              1
50/0/43
20036  pots  up   up             3000$              2
50/0/44
20037  pots  up   up             601$               0
50/0/51
20038  pots  up   up             602$               0
50/0/52
20039  pots  up   up             603$               0
50/0/53
20040  pots  up   up             604$               0
50/0/54
20041  pots  up   up             115$               0
50/0/55
40000  voip  up   up             125                0  syst ipv4:192.168.50.50:6
OmegaES-VG#
OmegaES-VG#
the uc; when somone call the 125; send calls to the srp!!
but calls do not reach the IPHONE!
