Jabber video call with call manger 10.5
renji joy
Hello Team,
We are trying to register the jabber client with call manaer 10.5 for the video calling,
How we can achive the video call feature with this setup.please find the version
call manager version 10.5
Jabber cleint 10.6
please suggest for the same.
Thanks in Advance
17 Replies 17
Jaime Valencia
Simply configure Jabber for windows as per the documentation, that's it, video calling is already enabled by default, have you tried it????
Assuming they're in different regions, simply make sure to allow enough BW between them for video to be used.
java
if this helps, please rate
Thanks for your quick replay,
We are trying make call in the same lan.
I have tried the same but the jabber is not registering in the call manger
We ahve configured devicename with starting CSF also asociated the one user,but its not getting registered.
please find the attched screen shot .
What did you configure under Advance Settings? Please share the screen shot of the same.
- Vivek
Hello
Please find the attched device confifuration page,
It seems you're trying to login with DN (5000). Please note that you need to use end users user id for login, not DN.
BTW, I asked you what did you configure under Advance Settings? (settings below to username and password in Jabber).
- Vivek
I have configurd the username is 5000,
end user name 5000,aslo please find the attched adavnced setting screen shot.
In of the thread, you've mentioned call manager version 8.5 and other time, 10.5. Which version you're using?
- Vivek
Currently i am trying to register with call manger 10.5
Ok, if your end users user id is 5000, CSFTEST device with respective end user is associated and DN is also assigned to CSF device, nothing additional required for Jabber to registered with CUCM. Please check the connectivity between your computer and CUCM. In addition, take PCAP traces from computer and see what all messages are exchanged between Jabber and CUCM, this may give some hint to check further.
- Vivek
for video to work, make sure that video is allowed between the regions of the calling and called device. if your Jabber clients are in the same device pool, the by default your intra region settings will allow video.
are you using srv records to resolve your cups server at login?  in which  case, use your domain name to log in        like john.doe@acme.com.au for instance
Please remember to rate useful posts, by clicking on the stars below.
Hello ,
Currently we dont have any presence server ,only we are using the call manager 10.5
No presence server?  then what is your intention fwith Jabber? what do you want to use it for?
Currenlty we are using vcs with other end points,we need to indtegrate with jabber setup with vcs .
Configure a SIP trunk on CUCM side and a neighbor zone in VCS to make calls between them.
java
