08-09-2017 04:26 AM - edited 03-18-2019 12:19 PM
There's a longer story behind this and we may not need to attempt this, but just in case, I wanted to get the answer as to whether it's even possible.
So, if we have a 4331 router in South Korea with a NIM-2MFT-T1/E1 module and we configure the 4331 as a H323 gateway (or even MGCP) in CUCM, is it possible to have one port on that NIM-2MFT-T1/E1 module configured for E1 R2 and the other port on the same module configured for E1 ISDN PRI?
Solved! Go to Solution.
08-09-2017 05:52 AM
I can't find a doc that says explicitly, but I don't see why this would be a problem as you can configure the two ports independently such as:
08-09-2017 05:52 AM
08-09-2017 06:02 AM
Ok, thank you. I just wanted to be sure in case we had to attempt this. We have an order to change the old E1 R2 to ISDN, but in case it wasn't ready in time I wanted to know our options.
