Large Scale Analog phones on CUCM 8.6
angel-moon
Level 3
Level 3
                   Hello everyone,
the need is for about 500 analog phones connecting back to to CUCM 8.6.  Does anyone have a way to get that many analog phones over to CM using something other (read cheaper) than VG224s?
Thanks in advance!  All replies rated.
Chris Deren
New VG350 GW is the other option:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/gatecont/ps2250/data_sheet_c78-710996.html
though I have not done cost comparison, if you do one, make sure you consider annual smartnet support as well, power consumption, etc.
HTH,
Chris
Chris Deren
HTH,
Chris
