02-09-2015 04:19 AM - edited 03-17-2019 01:53 AM
Hii,
I have Cucm10.5 installed and I want to create an export from cucm with License Count Utility to see the licence but I have a problem with login. On cucm8.6 everything was OK but after update i receive the error from attachment. Do I have to check some other Service on cucm10.5 or????
The password is OK because i log in with the user name and password to Cucm to see if is OK.
Pls check the attachment
Solved! Go to Solution.
02-09-2015 05:30 AM
Hi Gabi,
The LCU won't run against the 10.x CUCM, as it is intended only to connect to 8.x and
earlier CUCM versions.
HTH,
Mohammed Noor
02-09-2015 05:02 AM
Not sure what exactly the issue you are encountering. Just wondering if you could just add a new user, give that user all the Roles and Permissions, and then try with that account?
02-09-2015 05:12 AM
Hi Samuel,,
I logged in like in cum8.6 but on cucm10.5 I receive the error from attachment. The same user and password like before. I create a user "test" with the proper rights but the same problem:(
02-09-2015 05:27 AM
Are u using Application Username and password?
May be u are entering OS adminsitration credentials and so , it is not working.
regds,
aman
02-09-2015 05:03 AM
Hi Gabi,
Have you verified the application userid which you use to connect to License Count Unity has Standard AXL API Access Role/Access Group. Try using administrator user and check if that work.
Mohammed Noor
02-09-2015 05:09 AM
02-09-2015 05:19 AM
Hi Gabi,
Have met below pre-req as per admin guide
Operating system:
Java 6: www.java.com/en/download/faq/java_6.xml
If you have firewall in your PC disable it. Are you able to browse the webpage of the server you trying to connect. You may also try disabling SELinux mode to permissive on CUCM "utils os secure permissive" and check if that helps
HTH,
Mohammed Noor
02-09-2015 05:32 AM
Hii,,
I have Windows7/64
I Disable the firewall
I have Java installed in my pc: Java 6, Java 7, Java 8
02-09-2015 05:45 AM
i thought u are using LCU with CUCM 8.6.
why u want to use LCU with CUCM 10.x when u have licensing segregation as per UCL/CUWL in PLM?
In CUCM 8.x, it was DLUs so , we need to run LCU to share that licenses required as per UCL essential,UCL Enhanced /Enhanced Plus and CUWL std
regds,
aman
02-09-2015 05:30 AM
Hi Gabi,
HTH,
Mohammed Noor
02-09-2015 06:56 AM
Correct for the Licenses one has to run PLM on the 9.x onwards :-)
