License required for 3rd party IP Phone
subratabiswas1
Refer to below BoM would you kindly guide with the right license for 3rd party IP Phone to sync with the existing infra.?
Call Manager Hardware
21.0
BE6M-M4-K9=
Cisco Business Edition 6000M Svr (M4), Export Restricted SW
N/A
CON-SNT-BE6M4M4K
SNTC-8X5XNBD Cisco Business Edition 6000M Svr (M4), E
12.0 month(s)
CAB-250V-10A-ID
AC Power Cord - 250V, 10A , India
N/A
VMW-VS6-HYPPLS-K9
Embedded License, Cisco UC Virt. Hypervisor Plus 6.x (2-cpu)
N/A
CIT-PSU1-770W
770W AC Hot-Plug Power Supply for 1U C-Series Rack Server
N/A
CIT-CPU-E52630D
2.40 GHz E5-2630 v3/85W 8C/20MB Cache/DDR4 1866MHz
N/A
CIT-MR-1X161RV-A
16GB DDR4-2400-MHz RDIMM/PC4-19200/single rank/x4/1.2v
N/A
R2XX-RAID5
Enable RAID 5 Setting
N/A
CIT-MRAID12G
Cisco 12G SAS Modular Raid Controller
N/A
CIT-MRAID12G-1GB
Cisco 12Gbps SAS 1GB FBWC Cache module (Raid 0/1/5/6)
N/A
Call Manager Software
22.0
R-CBE6K-K9
Cisco Business Edition 6000-Electronic SW Delivery-Top Level
N/A
CON-ECMU-RCBE6KK
SWSS UPGRADES Cisco Business Editi
12.0 month(s)
BE6K-START-UWL35
BE6000 Starter Bundle with 35 UWL Standard Licenses
N/A
JABBER-GUEST
Jabber Guest Session
N/A
100
22.3
UCXN-11X-SCPORTS
BE6K - Unity Connection 11x - VM Speech Connect Ports
N/A
JAB-GUEST-RTU-K9
Jabber Guest Right to Use
N/A
LIC-EXP-E-PAK
Expressway Series, Expressway-E PAK
N/A
LIC-EXP-GW
Enable GW Feature (H323-SIP)
N/A
LIC-EXP-E
Enable Expressway-E Feature Set
N/A
LIC-EXP-TURN
Enable TURN Relay Option
N/A
LIC-EXP-AN
Enable Advanced Networking Option
N/A
LIC-SW-EXP-K9
License Key Software Encrypted
N/A
LIC-EXP-SERIES
Enable Expressway Series Feature Set
N/A
EXPWY-VE-E-K9
Cisco Expressway-E Server, Virtual Edition
N/A
BE-11X-UWLS-STR
BE6000 v11 UWL Standard Starter licenses
N/A
CON-ECMU-BE11WXUR
SWSS UPGRADES BE6000 v11 UWL Standard Starter licenses
12.0 month(s)
BE6K-UXL-START
BE6K Starter Pack - Single Fulfillment Enforcement
N/A
EXPWY-VE-C-K9
Cisco Expressway-C Server, Virtual Edition
N/A
SW-EXP-8.X-K9
Software Image for Expressway with Encryption, Version X8
N/A
BE6K-PAK
Cisco Business Edition 6000 - PAK - Single Fulfillment
N/A
LIC-EXP-DSK
Expressway Desktop Endpoint License
N/A
500
22.19
BE6K-SW-11.5
Business Edition 6000 v11.5 export restricted software
N/A
BE6K-UCL-ENHP
Cisco Business Edition 6000 - Enhanced Plus User Connect Lic
N/A
465
22.21
UCM-11X-ENHP-UCL
BE6K UCM 11X Enhanced Plus User Connect Lic - Single Fulfill
N/A
465
22.21.0.1
CON-ECMU-UCMUCENH
SWSS UPGRADES BE6K UCM 10X Enhance
12.0 month(s)
465
Thank you in advance, for your guidance.
Rgds.
Subrata
Gregory Brunn
A sip third party device type in CUCM should utilize an enhance user connect license in version 10-11
https://www.cisco.com/c/dam/en/us/products/collateral/unified-communications/unified-communications-licensing/C45_523902_11_9_licensing_aag_v5a_1.pdf
If you already have cucm installed build a third party sip device and you should see the license count needed for users go up by 1.
Gregory Brunn
