Licenses help
mohamed sebaey
I need just confirmation, i have 3 cisco servers ( one pub , two sub). I have already installed three servers , for licenses for IP phones
1- is the licenses will be installed for every server or just the pub and it will be enough.
2- is there will be any other license for PUB to recognize other two servers (two sub).
please help
6 Replies 6
Jaime Valencia
All those questions depends on what version you're asking about.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Thank you for your reply , the version is 8.6 . I have other question ( i have three servers , how can i distinguish between them to make one pub , other two sub ot it is random).
this the output configuration for licenses
part number                             descr        QTY
CUCM-USR-LICTop Level Sku For User   License1
LIC-CUCM-USR-AUnified   Communications Manager Enhanced Single User-Under 1K195
UCSS-UCM-1-1-AUC   Manager Enh UCSS Less than 1K users - 1 user - 1 year195
LIC-CUCM-ESS-AUC   Manager Essential - Less than 1K Users5
UCSS-UCM-ESS-1-1-AUC   Manager Ess UCSS Less than 1K users - 1 user - 1 year5
PUBLIC-IP-DEV-ADDPub.Space   non-app phone add-on lobby, conf. room phones5
UCSS-PUB-1-1UCSS for   UCM Pub user for One Year - 1 user5
UCM-7825-85CUCM 8.5   78251
CCX-85-CMBUNDLE-K9CCX 8.5   5 Seat CCX ENH CM Bundle - AVAILABLE ONLY FOR NEW CM1
CUCM-PAKInclude   PAK Auto-expanding PAK for CUCM1
CUCM-USRInclude   PAK Auto-expanding User for CUCM1,195
UCM-7825-85-KITCUCM 8.5   Media Kit1
UCM-7825-NODECUCM   7825 Node1
UCSS-PUB-PAKUCSS   Public Space Devices Product Authorization Key1
UCSS-UCM-ESS-PAKUCSS for   UCM Essential PAK1
UCSS-UCM-PAKInclude   PAK Auto-expanding UCSS PAK for CUCM1
CON-ESW-CMBUNDK9ESSENTIAL   SW CCX 8.5 5 Seat CCX ENH CM Bundle - AVAIL1
CON-ESW-CUCMUSRESSENTIAL   SW Top Level Sku For User License1
CON-ESW-CUCMESSAESSENTIAL   SW UC Manager Essential - Less than 1K User5
AIR-CT5508-250-K9ESSENTIAL   SW Unified Comm Mgr Enh Sngle User Under 1K195
CON-ESW-PUBLICIPESSENTIAL   SW PubSpace non-app phone add-on lobby5
Cisco   MCS Server for CUCM
MCS7825I5-K9-CMD2Unified   CM 8.5 7825-I5 Appliance, 0 Seats3
CAB-ACEAC Power   Cord (Europe), C13, CEE 7, 1.5M3
CON-SNT-MCS78257SMARTNET   8X5XNBD Unified CM 8.5 7825-I5 Appliance3
thanks
Then you use the PUB MAC address for all licenses, you need DLU license, node license and SW feature license.
You choose upon install if it's going to be a PUB or SUB.
And you need 3 node licenses.
java
java
Thank you so much , i have the last question ( it is ok to install the 3 servers , after that set the licenses file upload to them). Other thing the licenses will be uploaded only for the pub (not the two sub).
Yes, you bind all the licenses to the license server, and install all of them there.
You can install it, but won't be able to start CUCM services until licenses are installed.
java
java
Hi Mohamed,
You can generate the Node /Feature licenses by using MAC -address of Publisher and upload them only in Publisher.
You can either send the mail to licensing @cisco.com by providing MAC-address and Sales Order Number or visit the site  www.cisco.com/go/license .
Later on, u can add Subscribers to the cluster.Licenses are never uploaded to Subscribers.
regds,
aman
