IP Telephony and Phones
Labels
Hi,today i got aware of Bug-ID CSCth87452 with the above Title. Does anybody know if this bug is fixed in CUCM/CUC Version 9.1.1(a)? The Fixed-In INformation tells about some 8.X and 1.0.X Version, but nothing about 9.X Versions.Any help is welcome!/...
Hi All We got two branches:Site A is registered to CUCM 8.0.2 on HQ and have HW-CFB on site.Site B is registered to CUCM 7.1.2 onsite and have HW-CFB as well.We have an ICT (Non-Gatekeeper Controlled) between CUCMs.When phone 1-A calls to phone 2-A w...
Hi,I have a problem with a ATA187, after switch off and on to change from one port to other, now all the lighs are always on, after few minutes make a quick flash, and again all are lights on.I tried to conect a analog phone to make a default restore...
Hi All ,,The CME is runing in the cisco 2811 rotuer and configured the h323-gateway voip  in the Sub-interface for Voice VLAn interface GigabitEthernet0/0.20 description Voice Vlan encapsulation dot1Q 20 ip address *.*.*.* ip flow egress h323-gatewa...
Hi Experts,                   This is some thing weird problem...whose area code starts with 9 and when they try to call FXO pots line after first ring they get dial tone then ends with fast busy signal...When I tried with all possibilities I figured...
mshamkumar by Level 1
  • 3204 Views
  • 19 replies
Hi,I am facing an issue while dailing from my jabber client. I am using CCM 8.6 with H323 gateway. From Cisco IP phone I am able to dial all the number bit from my jabber client I am able to dail some specific numbers. Can you please help me out in t...
