Limit Call Duration on CME‏
ievalleyccie
I wonder if there is a way to configure call manager to disconnect a
call after let's say 10 minutes. I have searched the entire CallManager
administrator guide, but could not find any such option. The goal is to
limit certain users/numbers to a maximum time they can call...
Thanks for your help in advance
Jaime Valencia
You mention CUCM and CME, neither of them can do it. You would need to do TCL scripting
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Aditya Gupta
Maybe you want to check this parameter on CUCM "Maximum Call Duration Timer "
This can be found under CUCM Admin page: System--> Service Parameter -->Cisco Call Manager.
That's a global parameter and will affect ALL calls
java
java
Robert Thomas
Level 7
Level 7
For CME I'm not aware of the parameter, and CUCM would only contain the parameter Aditya mentioned and that would affect all calls on the system. It's usually set to a large value like 14 hours, in case a calls stays up due to an unknown reason for a very long time.
