Calls to the remote office via PBX
kuliyevnatik
Hello, when i call from Cisco to PBX all is ok
But when i want to call to remout office via PBX after 15 seconds is error, becaus now is configured like this (Remoute_office --->PBX--->CiscoGW)
The debug of isdn q931 says
Voice#
Oct 23 05:10:25.943: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0004
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Calling Party Number i = 0x0081, '1012'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '7101190'
Oct 23 05:10:26.143: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8004
Oct 23 05:10:34.159: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x8004
Oct 23 05:10:34.159: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x0004
Oct 23 05:11:00.439: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x8004
        Cause i = 0x80AA - Switching equipment congestion
Oct 23 05:11:00.463: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x0004
Oct 23 05:11:00.479: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8004
Voice#sh voice dsp group all
DSP groups on slot 0:
dsp 1:
  State: UP, firmware: 28.3.5
  Max signal/voice channel: 16/16
  Max credits: 240, Voice credits: 240, Video credits: 0
  num_of_sig_chnls_allocated: 16
  Transcoding channels allocated: 0
  Group: FLEX_GROUP_VOICE, complexity: FLEX
    Shared credits: 240, reserved credits: 0
    Signaling channels allocated: 16
    Voice channels allocated: 0
    Credits used (rounded-up): 0
  Slot: 0
  Device idx: 0
  PVDM Slot: 0
  Dsp Type: SP2600
dsp 7:
  Max signal/voice channel: 32/32
  Max credits: 480, Voice credits: 480, Video credits: 0
  num_of_sig_chnls_allocated: 32
    Shared credits: 480, reserved credits: 0
    Signaling channels allocated: 32
  Slot: 0
  Device idx: 0
  PVDM Slot: 1
  Dsp Type: SP2600
dsp 8:
  num_of_sig_chnls_allocated: 12
    Signaling channels allocated: 12
  Slot: 0
  Device idx: 0
  PVDM Slot: 1
  Dsp Type: SP2600
DSP groups on slot 1:
This command is not applicable to slot 1
  0 DSP resource allocation failure
Voice#
can anybode help? why error come
Jonathan Schulenberg
You need to ask the person who manages the PBX what's going on. The Cisco gateway receives the DISCONNECT IE so it's not at fault here. I do not believe this is a timer problem since the call fully connects and then the PBX tears the call down.
Thanks Jonферфт, I thought so too
