Limit outside call to 5 or 10 minute
CSCO11328190
  Dear all ,
    I hope all are fine ,  Please i need your assistent .
    I use CUCM 6.1 , i want to make limit to  call  outside my network to  5 or 10 minute max .
Thanks , and waiting for your replay .
Best Regards ,
Jaime Valencia
No way to do such thing with CUCM, there's a parameter for maximum call time but it affects ALL calls.
What you're asking can only be done with TCL scripting.
Similar questions have been asked plenty of times before, please search CSC for answers before posting.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
   Dear Mr.javalenc ,
    Thank you for your reply . Please can you give me the steps to doing that .
   and from where i can get the TCL scripting .
Best Regards,
