10-19-2017 08:45 AM - edited 03-18-2019 12:21 PM
Where in Unity Conn do you "link" the VM profile /Directory Number to the SIP
When you dial the VM DN ,how are calls routed to select to use the SIP trunks so to be routed to Unity- thanks
Solved! Go to Solution.
10-19-2017 10:44 AM
You set up a route pattern for the pilot #. The RP points to a RL with a route group containing the trunk.
10-19-2017 10:44 AM
10-20-2017 02:31 AM
Many thanks, that was it
I did a dependency on the VM # and Profile which only pointed to what DN`s were using it and doesn`t show the Route pattern - so that threw me
thanks
