You mean the user which you created on the AD is not updated on CUCM after the SYNC ?
check if the user has a last name mentioned on AD. User will not be imported if it has only first name in AD.
Your call handler extension and the user sync has no relation.
Can you explain a bit more about the setup and the use case ?
