01-12-2011 09:47 AM - edited 03-16-2019 02:50 AM
since CUCM on UCS doesn't support USB, it seems that an MCS server has to be deployed to accomodate the USB sound card, has anybody have other idea? such as retrieve the audio stream from a router voice port, like what CME does.
thanks!
Solved! Go to Solution.
01-12-2011 10:01 AM
The recommendation is to use a standalone MCS to handle MoH.
Pierre.
01-12-2011 10:56 AM
You can still use the SRST as multicast MOH config while using UCS if that's what you're asking.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
01-12-2011 09:58 PM
I'm doing it off a router instead. Take a look at this reply: https://supportforums.cisco.com/message/3265999#3265999
01-12-2011 10:01 AM
Pierre.
01-12-2011 10:56 AM
java
01-12-2011 09:58 PM
01-13-2011 11:29 AM
all replies help. i'll keep one of existing MCS servers to do the MoH for now, this is the easiest and safest way. I believe CUCM on UCS will support USB someday, then this MCS can be decommissioned. thanks guys!
