Lock out Unity Connection account after user account VM PIN expirs
saurabh_om
I am looking to apply a condition in Unity connection where user VM account should get locked after VM account PIN is expired (as set duration in authentication rule).
As of now when PIN expired duration is over, system is prompting to reset new PIN if I am login inn with correct old pin number.  I am looking to block any such attempt and give privilege to system admin to reset it.
Unity connection version - 8.6
Thanks Saurabh
Wilson Samuel
Level 7
Level 7
It should be under System Settings > Authentication Rules (it will change the settings for clusterwide users) , if for a single user, the User > Edit > Password Settings
I don't think this is achievable to lock users on expiration.
