Logged Into Hunt Group Softkey on ip phone 3905
Agustin Varela
need to do a question ans see if someone can help me.
I have a cucm 10.5.2, I create a hunt group number with only 3905 members within it. In the phone page of my 3905 phones I have the "Logged Into Hunt Group" option enable, then I add the softkey "Hlog" for the users can enter or exit the hunt.
the problem is that i assingn the softkey to the phone but i cant see it when press the center button of features.
any ideas? or 3905 doesn t support this? or i mess something?
thanks in advance
best regards.
7 Replies 7
Jaime Valencia
The 3905 does not support the hlog softkey. The options for softkeys are limited for that model.
java
if this helps, please rate
Perfect Jaime, thanks so much.
regards
Hi Jaime,
So, is there any way to do Huntpilot login & logout  from the 3905 IP phones?
Maybe dialing a feature code?
Pablo
There are no feature codes in CUCM for such thing, the only ones that exist, are for MVA usage only.
java
Jaime,
Thank you very much for your quick answer.
So there is absolutely no way for login/logout a 3905 telephone from a hunt group. Is it Correct?
regards,
Pablo
Correct, you need a model that does support softkeys to use the hlog softkey.
java
Ok. Thank you very much for your help Jaime.
Best regards,
Pablo
