There are no records of SSH, the system only saves the last record and shows you the info immediately after you log.
For CUCM you can look at Role Based Security traces.
For access to any webpage the only option are tomcat traces.
No tracing whatsoever for anything related to pwds.
java
if this helps, please rate
java
