long beep when call to FXO
Garry-the-Axe
Hello, I have some issue with calls on FXO to FXS ports when using CUCM. So, I have 6 FXO ports and 8 FXS/DID ports registered in CUCM. When I call from PSTN to one of this FXOs then after first beep, there is long beep. And only after that call happening and called party hear ring on analog phone. Is anyone know anything about this?
Gajanan Pande
Vyacheslav,
What is the CUCM version ?
What is the gateway router model & IOS version running into it ?
GP.
CUCM version 6.1.4.1000-10.
Router 3825 IOS version C3825-SPSERVICESK9-M  12.4(3i)
Customer use EVM-HD-8FXS/DID with EM-HDA-6FXO
signal method is loop start on both FXS and FXO.
MGCP is used for call control.
Also there is a E1 PRI configured on a gateway.
Thanks. I would try tweaking the signaling on FXO port among the options available there. I guess they are Ground Start & POTS.
Pls let me know how it goes.
GP.
Pls rate the post if it helps by clicking on stars below the post !!
