LONG-DUR-CALL marking
CSCO12111341
Hello all,
we notice that time to time we see on our routers calls which take days or even weeks.
I would like to know if there is any way how to mark such call to long-dur-call and then over simple script clear such calls.
So for example if call takes longer than 8 hours then it will be marked like this and every 12 hours we will automatically run script which will clear it.
We are using cisco 2921 15.4(3)M7.
Thank you so much in advance
Best regards
Lubos
Manish Gogna
Hi Lubos,
As per the following link
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-border-element/112095-cube-hsrp-config-00.html#anc13
Step 6: Configure the Media Inactivity Timer
The Media Inactivity Timer enables the Active/Standby router pair to monitor and disconnect calls if no Real-Time Protocol (RTP) packets are received within a configurable time period.
When RTP packets for a call are not received by the Active/Standby router, the SIP Media Inactivity Timer releases the session. This is used to guard against any hung sessions that might have resulted from the failover in the event that a normal call disconnect does not clear the call.
The same duration for the Media Inactivity Timer should be configured on both routers. The default value is 28 seconds. This timer is configured as follows:
ip rtcp report interval 3000
gateway
  media-inactivity-criteria all
  timer receive-rtp 86400
  timer receive-rtcp 5
Manish
- Do rate helpful posts -
