IP Telephony and Phones
Labels
Device: 8861 IP phone CUCM: 9.1 CUC: 9.1 upgraded to 10.5 Phone Service: 8861 Visual Voicemail. Service Details: We do have 2 VVM phone services set up.  One for all our other phones and is enterprise subscribed.  And the other is not enterprise subs...
magnum629 by Level 4
  • 1037 Views
  • 1 replies
we have several remote sites and I would like to connect a local PSTN POTS line to our routers for 911 services.  I have a test site and I am trying to configure my 2901 router (release 15.4.3.M7) to route all 911 calls to the FXO port 0/2/0. I am us...
Boa tarde preciso configurar um ata para que ele puxe '0' antes da linha pois minha maquina de cartao de credito esta configurada assim e agora a linha é direta, uso asterisk, o ata ja esta ligando normal se colocar um telefone mas preciso configurar...
douglasti by Level 1
  • 234 Views
  • 1 replies
I have several Cisco 7965G phones with a single Sidecar installed.Firmware Load SCCP45.9-4-2SR3-1SRunning CallManager 10.5.2.12901-1This never happens on 7965G phone that do not have a sidecar.Randomly when the user answers their second Line DN the H...
jmarateo by Level 1
  • 909 Views
  • 2 replies
I'm trying to update the Max Number of Calls and Busy trigger for 88XX using BAT update lines to Max Calls 10, and Busy 4. I'm getting the following error whenever that line is associated with Jabber CSF, TCT, BOT, TAB.  Update Lines - Query Query : ...
Hi guys, I have a problem with cp-7962 sccp registration on a CME version 11.2 running on a Cisco 2901 I have the following configuration telephony-service max-ephones 42 max-dn 200 ip source-address 172.29.230.2 port 2000 service dnis overlay ser...
19782401a by Level 1
  • 320 Views
  • 1 replies
We have 3 phones in a line group - Test-LG: 100011000210003 The line group settings are as follows:Distribution Algorithm - CircularHunt Options (all) - Try next member; then, try next group in Hunt List Our Hunt List - Test-HL only member is Test-LG...
dtom by Level 1
  • 163 Views
  • 2 replies
