Looking to enforce a custom Background Image on the Enterprise Cisco IP 7942 to default
Voiceops SSC
I just finished setting up a Background image for the Cisco phones in the company. I can already select the background image by going manually on each phone Settings-User Preferences-Background Images, but we have almost 500 7542Phones in the Enterprise and I'm looking to change the Background image on all the phones at once. I would also like the brand new phones to automatically select this background image once it gets registered to our CUCM.
Is there any way to do this?
Jaime Valencia
This topic has been covered hundreds, and hundreds, and hundreds of times at CSC, a simple search will provide you all the information on this.
Only 89XX and 99XX can be configured via CUCM to load a specific background, for all other models, all the previous threads on CSC have the answer to that one, which is no.
If you want to see the alternatives and what can be done, do a quick search.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
