- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
09-19-2012 05:35 AM - edited 03-16-2019 01:17 PM
Originally posted: 2012-Sep-18.
About a year ago, I informed Cisco that various pieces of documentation detailing the GB number plan were inaccurate, incomplete, and out of date.
The majority of the published data seemed to be from some time back between 2003 and 2006, but with a substantial number of additional errors and inaccuracies and certainly not up to date.
It has taken many months to get the documentation amended with the correct information, but those changes do not appear to have made it back into the software.
I have recently seen a copy of the cisco GB number plan version 18 'dp-ffr.1-1-18.GB.exe', 'dp-ffr.1-1-18.GB.cop.sgn', 'dp-ffr.2-1-18.GB.cop.sgn' and 'dp-ffr.3-1-18.GB.cop.sgn', released only a few weeks ago, and that still has the same and many other errors included.
The faulty GB number plan file is as detailed at:
Visit the above pages, mouseover the details there, then look for the 'flat pattern file' link in the popup box, specifically:
http://www.cisco.com/web/software/282074292/51298/GBNP.txt
This file contains a large number of errors.
I enclose the original and a corrected version of the 'flat pattern file'. The corrected version has dozens of fixes detailed within.
Solved! Go to Solution.
- Labels:
Other IP Telephony
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-20-2012 05:41 PM
Item 13
# 0+1697+7[23]XXX
P: 0 NATIONAL-ACCESS
P: 1697 AREA-CODE
P: 7[23]XXX SUBSCRIBER
U: Y
Ofcom's data incorrectly marked 0169772 and 0169773 as 4+4 for many years, i.e. 01697 72XX and 01697 73XX. Later these allocations were incorrectly marked as 4+5 for a while, i.e. 01697 72XXX and 01697 73XXX. Eventually in 2010 the data was corrected. These numbers are actually 5+4 format, i.e. 016977 2XXX and 016977 3XXX.
# 0+16977+[23]XXX
P: 16977 AREA-CODE
P: [23]XXX SUBSCRIBER
T: N
U: Y
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-02-2012 12:50 AM
Correction to Item 13.
Corrected my typo in the 16977+[23]xxx rule, in the post above and in the uploaded "corrected" files.
Changed from
T: Y
to
T: N
U: Y
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-20-2012 05:41 PM
Item 14
# 0+1298+2[2-7]XXX
P: 1298 AREA-CODE
P: 2[2-7]XXX SUBSCRIBER
U: Y
Numbers beginning 01298 28 are also 4+5 format with only 9 digits. Amend the 2[2-7] pattern to 2[2-8] here:
# 0+1298+2[2-8]XXX
P: 1298 AREA-CODE
P: 2[2-8]XXX SUBSCRIBER
U: Y
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-20-2012 05:42 PM
Item 15
01524 and 01827 were listed after 01364 and before 01384. This is not in numerical order.
As an obvious cut and paste error, they've been moved to the correct place in the new file.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-20-2012 05:42 PM
Item 16
# 0+1420+8[02-9]XXX
P: 1420 AREA-CODE
P: 8[02-9]XXX SUBSCRIBER
U: Y
Numbers beginning 01420 81 are also 4+5 format with only 9 digits. Amend the 8[02-9] pattern to 8X here:
# 0+1420+8XXXX
P: 1420 AREA-CODE
P: 8XXXX SUBSCRIBER
U: Y
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-20-2012 05:43 PM
Item 17
This rule can be deleted:
# 0+1557+50XXX
P: 1557 AREA-CODE
P: 50XXX SUBSCRIBER
U: Y
According to Ofcom, this allocation changed from 4+5 to 4+6 before 2004 and can therefore be deleted from the file.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-20-2012 05:43 PM
Item 18
Add an addditional rule:
# 0+1768+88[234678]XX
P: 1768 AREA-CODE
P: 88[234678]XX SUBSCRIBER
U: Y
The 01768 area code is marked as 'Mixed 4+5/4+6' in Ofcom data. Only numbers beginning 882, 883, 884, 886, 887, 888 are 4+5 format.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-20-2012 05:43 PM
Item 19
# 0+8720+XXXXXX
P: 8720 AREA-CODE
P: XXXXXX SUBSCRIBER
U: Y
0872 0XX XXXX numbers are already included within another rule that covers 087[1-3] XXX XXXX numbers.
Additionally, these are premium rate (small 'p') numbers.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-20-2012 06:53 PM
Ian, thanks for posting this. Have you opened a TAC case over the issue? I would suggest that if you have not already. I'd also lean on the account manager team to insure these issues get addressed.
-Mark Turpin
-Mark Turpin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-21-2012 11:59 AM
I have no way to raise a TAC case.
We'll just have to see whether whoever compiles these files monitors the forums.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-21-2012 11:57 AM
Item 20
There's other improvements that can be made in the premium rate services ranges beginning 09, but this would need at least one additional tag.
# 0+9[018]XXXXXXXX
P: 9[018]XXXXXXXX PREMIUM-RATE-NUMBER
T: N
This should be changed to something like this (this change is not mentioned in the .txt file linked at the top of page):
# 0+90[0-7]XXXXXXX
P: 90[0-7]XXXXXXX PREMIUM-RATE-NUMBER
T: N
# 0+90[89]XXXXXXX
P: 90[89]XXXXXXX PREMIUM-RATE-ADULT-SERVICES
T: N
# 0+91XXXXXXXX
P: 91XXXXXXXX PREMIUM-RATE-NUMBER
T: N
# 0+98XXXXXXXX
P: 98XXXXXXXX PREMIUM-RATE-ADULT-SERVICES
T: N
This change is the only one NOT mentioned in the uploaded corrected file at:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-21-2012 05:33 PM
Thanks Ian for posting this, I'll work on getting this information to the right group(s) so these changes can be made.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-21-2012 11:57 PM
Thanks for helping out.
I'm quite happy to discuss, line by line if necessary, any of these changes when you have found the right people.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-26-2012 08:14 AM
Ian, I wanted to let you know that I've reached out to the dial plan team to review your comments. I'm waiting to hear their feedback about it. I'll let you know if we need to talk with you about it. Thanks again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-26-2012 11:44 AM
Noted. Most of the comments should be self-explanatory, but ask away about anything you want...
Please make sure they have the latest version of comments and edited corrected file as I did fix a couple of typos.
