IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6152 Views
  • 14 replies
    Has anyone done an integration with callmanager express.  Problem I am running into is the customer wants a beep to indicate the call is being recorded. I understand that under straight callmanager with the sip trunk and profiles but not with cal...
whanson by Level 2
  • 308 Views
  • 1 replies
Dear All,I have a centralized CUCM cluster running 8.5 and have plenty of remote sites.Now I would like to have Automated Attendant  feature to be deployed at one of the remote site.AA should play basic greetings like welcome to XYZ , press1 for sale...
i have two problems i have cucm v7 and gateway which connected to E1 , outgoing all are ok.Incoming calls are hit the gateway but i get an errir in debug isdn q931 unallocated unassigned number , i am sure of my configuration. Please help , i shared ...
I am running a 2951 voice gateway with the 15.1(2)T5 IOS code.There is a way to add the 6945 as a custom built ephone type. Once built it will work. Does anyone know exactly what info is required after you define it using:ephone-type 6945   command?A...
Hi ,I'm trying to register 8945 with CME 9.1 however unsuccessfully. The phone keeps display "Phone not registered". I've tried to upgrade phone firmware to 9.1 by:tftp-server flash1:8945/SCCP894x.9-2-2-0.loads alias SCCP894x.9-2-2-0.loadstftp-server...
Thang Le by Level 1
  • 1417 Views
  • 1 replies
Hi NetProI have this issuePhone A = InternalPhone B = InternalPhone C = External        Phone D = ExternalI have setting up the partition al CSS for CFW. and i have this problem:When phone B CFW to phone A, if i call from phone C the CFWA ok.When pho...
