Make a trace to an IP set
Hi guys, I wonder if you can help me.
I have a CM 7 and want to trace a particular set, see what he is dialing, status, etc.
I tried to open the "View RealTime" but a lot of messages are flooding the monitor.
Is there a way to trace a set and see what is doing - dialing, signaling, etc - ?
If so can you tell me how?
Please help me.
Best Regards,
2 Accepted Solutions
Drop the idea of looking at them real time, not even TAC does that with the amount of information that you get from a single call. Now imagine how it would look in a live system without any kind of filtering.
Make the call, download the txt and review it
Set Up Cisco CallManager Traces for Cisco Technical Support
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml
If you're not familiar with CUCM traces nevermind the SDL traces right now, just look at the SDI traces (like the one i posted, it's also a small part of the whole line).
There is no specific method to find the TCPid, i just search for dd=" (dialed digits), that line will contain the calling number and i start searching above those lines for the keypad presses.
If you know the time they started the call you can easilly find it based on other data, but i guess the above would be the easiest if you're not familiar with traces.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
I am with Java on this one.  The only way to make real time tracing useful is to tail the trace file and grep for the strings you want to monitor on the screen.  RTMT's "live" trace isn't able to do that type of dynamic filtering and I have found that it doesn't refresh the way I would like anyway.
In most cases where you want to dissect a trace, you can setup your call scenario, note the time stamp, execute the call scenario, and then collect the traces using RTMT.  Once you have the trace files, use notepad++ or some other text editor to view.  I prefer notepad++ because for the reasons Java and I eluded to in earlier posts.  It is a very powerful, yet simple text editor.
Now, actually dissecting a trace and getting to the bottom of an issue is a whole other matter.  It just takes practice.
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
6 Replies 6
William Bell
You can configure your trace settings for the Call Manager service to do Device Name based tracing and focus on the device you wish to monitor.  You still get messages not directly related to the device but it will be an improvement over what you are looking at now.
Check this URL:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/7_0_1/admin_master/satrace.html#wp1130143
And look at the procedures in that section.
I have also found that pulling the trace file down to my PC and using an application like notepad++ to be helpful in filtering traces and getting the meat of the matter.
HTH.
Bill
Just to add something to Bill's great advise, the easiest way to find out what a phone is doing is just to locate the TCPid from the trace and then just mark them.
I also use Notepad++ to review traces, very nice tool since you can choose it and mark all the occurrences which makes life a lot easier.
I won't paste a whole call but you can understand what's happening by just reading this:
StationInit: (0202468) OffHook.
StationD:    (0202468) DisplayPromptStatus timeOut=0 Status='€ ' content='Enter Number'
StationD:    (0202468) StartTone tone=33(InsideDialTone)
StationInit: (0202468) KeypadButton kpButton=0.
StationD:    (0202468) StopTone.
You can also tell if the message is coming from the phone or from CUCM with the above, just look carefully.
java
java
Hi, thanks for the reply. I just have one difficulty that I'm trying to see the logs on real time. I activated the traces and only selected two sets to be traced and then went to real time monitor chose the callmanger site and then sdl tarce and start making a call.
The output is like that:
000031429| 2010/02/18 09:14:38.621| 001| SdlSig    | StationMediaPathEvent                 | restart0                      | StationD(1,100,40,3)            | StationInit(1,100,39,1)         | (1,100,39,1).15161-(SEP0024C4BE2909:192.168.253.102)| [R:LP - HP: 0, NP: 0, LP: 0, VLP: 0, LZP: 0 DBP: 0]ID=3 Event=1
000031430| 2010/02/18 09:14:41.547| 001| SdlSig    | ReapOldTokenRegistrationsTimer        | wait                          | SIPStationInit(1,100,46,1)      | SdlTimerService(1,100,3,1)      | (1,100,113,1).1-(*:*)                   | [R:HP - HP: 0, NP: 0, LP: 0, VLP: 0, LZP: 0 DBP: 0]
000031431| 2010/02/18 09:14:41.607| 001| SdlSig    | DeviceEventReceiptMonitoringTimer     | wait                          | StationInit(1,100,39,1)         | SdlTimerService(1,100,3,1)      | (1,100,113,1).1-(*:*)                   | [R:HP - HP: 0, NP: 0, LP: 0, VLP: 0, LZP: 0 DBP: 0]
This is a smal portion of the info that apperas on the screen.
I tried to collect the trace file but I have a problem, after I chose the CM Service Call manager I press next and then I don't know which service I chose to download the trace related to the sets.
Can you help me? Also can you tell me how to find the TCP id of a set?
My CM is 7.
PS: I came from the PBX world and I'm use to trace sets and see his status individualy and CallManager is much different related to this issue.
Best Regards,
Jose Carlos
java
java
HTH.
Bill
Thanks guys for all your help.
I did not saw the SDI trace when I collected the files from the CCM, only the SDL file, but, maybe, I made something wrong.
I will try again.
Hope not need, often, to use the debug or I will lose the rest of my hair.
On the Nortel world, debugging is easier and more direct - not so many garbage.
Best Regards,
Jose Carlos
