make cucm iso 10.5.2 bootable
monasir
Hi guys,
I'm trying to make cucm v 10 bootable but its not working.
I'm using Ultra iso with this link
http://htluo.blogspot.nl/2010/04/how-to-make-non-bootable-iso-image.html
I can choose either extraxt from floppy drive or DVD but i'not using both because i have downloaded the files into my pc.
I have the ISO's downloaded they are not on disc.
How can i make this properly worked?
double check a few things ...
1) Open UltraISO
a) In File > Open ... select you CUCM ISO.
b) In Bootable > Load Boot File .... select the Boot.info file
c) In Bootable > select Generate Bootinfotable
d) In File > Save As ... save your bootable CUCM ISO
Hope this helps
Ayodeji Okanlawon
I have done this many times and have not had any issues. Have made your boot file?
You need your boot file first.
Please rate all useful posts
1) Open UltraISO
Hope this helps
Jorge Mosquera
Hello @monasir .
We are looking for CUCM 10.5.2 ISO File and I and I could see that you had a post in the Cisco community where you were trying to make it bootable.
Do you have 10.5.2 ISO files? Could you share it with me?
Thanks for your attention.
Jorge Mosquera
