01-29-2013 02:33 PM - edited 03-16-2019 03:25 PM
Hello All,
Suddenly PSTN incoming calls are not working for perticular range of DID. When i dial the number from outside, the calls are dropping after giving busy tone, before busy tone im hitting 10secs of silence. Checked the followings:
1. Users partition is in gateway's CSS
2. There is no Translation pattern or route patteren for same DID.
3. Getting the error message "Mandatory information element missing" in Debug ISDN q931 and getting value 96 in "origCause_value" CDR.
Am i missing anything?, please let me know.
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98382
Exclusive, Channel 2
Calling Party Number i = 0x2181, '47252'
Plan:ISDN, Type:National
Called Party Number i = 0x80, '2007'
Plan:Unknown, Type:Unknown
Jan 29 17:02:32.779: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x03CE
Cause i = 0x8090 - Normal call clearing
Jan 29 17:02:32.819: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x83CE
Jan 29 17:02:32.839: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x03CE
Jan 29 17:02:33.163: ISDN Se0/0/1:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8341
Jan 29 17:02:33.163: ISDN Se0/0/1:23 Q931: TX -> ALERTING pd = 8 callref = 0x8341
Progress Ind i = 0x8088 - In-band info or appropriate now available
Jan 29 17:02:33.187: ISDN Se0/0/1:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0341
--More-- Cause i = 0x82E018 - Mandatory information element missing
Jan 29 17:02:34.775: ISDN Se0/0/1:23 Q931: RX <- SETUP pd = 8 callref = 0x0342
Bearer Capability i = 0x8090A2
Standard = CCITT
Jan 29 17:02:34.775: ISDN Se0/0/1:23 Q931: TX -> SETUP_ACK pd = 8 callref = 0x8342
Murali
01-29-2013 03:15 PM
Please post your full config, the calling number is only 5 digits, can you try making a call from a number that is properly presented, i.e. your cell phone?
Is thi H323/MGCP or SIP GW?
Chris
01-29-2013 03:16 PM
Murali,
You need tp report this to your TELCO
Alex.
Please rate useful posts.
01-29-2013 05:48 PM
Check if the far side is a 4ess switch. It sounds like an sdn service if so you need to set you switch type to 4ess and add NSF service sdn to the dch config.
