many extension to first available line
mrzh009811
hi friends,
i have 5 extension as below:
101, 102, 103, 104, 105
and 3 pstn lines on sangoma voip-gateway,
i want when for example extension 101 dialed a number, call goes out from first available line on sangoma,
and if extension 102 dialed a number, call goes out from next available line on sangoma,
how to this?
config must be done on cucm or sangoma-voip-gateway ?
Jaime Valencia
Most likely you have a sip or h323 trunk to that 3rd party GW, correct?
if so, then this has to be configured in the GW.
java
if this helps, please rate
Jaime Valencia
java
yes, it seems the config must done on gateway,
after searches in google, i founded hunt scheme protocol which works on cisco router with fxo card, not in cucm,
thanks a lot jaime,
