verify services and database
bluesea2010
Level 5
Level 5
migrtion
After migrating cucm 7.x to new version ,
How did we verify the integrity of the database and other services
What are the need to ve verified to see if there is no error ?
Georgios Fotiadis
Use serviceability to verify that the services of your interest are up and running and Real-Time Monitoring Tool to verify DB replication.
Troubleshooting CUCM Database Replication in Linux Appliance Model
Georgios
Please rate if you find this helpful.
Not sure what do you mean by integrity.
You can verify the services from serviceability windows. Look at feature
and control services and make sure that enabled services are running. For
DB, go to CLI and run the command utils dbreplication runtime. This will
show you the DB status which should be 2 for all peers.
