02-19-2019 05:21 AM - edited 03-17-2019 02:08 PM
Could you help me understand how to match incoming pots dial-peer with voice-port?
I have isdn pri trunks and I need to match evry trunk by using port on dial-peer.
it's written: "
Voice-port (associated with the incoming call setup request) with configured dial peer port (applicable for inbound POTS call legs) If no match is found with destination-pattern "
I tried to set only one dial-peer with port but the dial peer wasn't matched and the call was passed to dial-peer 0.
dial-peer voice 8 pots
permission orig
direct-inward-dial
port 0/1/1:15
forward-digits all
279174: Feb 19 11:58:30: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8 callref = 0x1697
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18383
Preferred, Channel 3
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0xA1, '6755'
Plan:ISDN, Type:National
Called Party Number i = 0x81, '2577'
Plan:ISDN, Type:Unknown
Locking Shift to Codeset 6
Codeset 6 IE 0x28 i = 'I.M'
zav7-r5#
279175: Feb 19 11:58:30: ISDN Se0/1/0:15 Q931: Received SETUP callref = 0x9697 callID = 0x5B12 switch = primary-net5 interface = User
279176: Feb 19 11:58:30: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x9697
Cause i = 0x80AF - Resource unavailable, unspecified
02-19-2019 05:32 AM
02-19-2019 06:11 AM
I wanted to prevent loops. If some troubles happened in call routing from pbx side I wanted to khow from what trunk a call came no to send it back to the same trunk.
02-19-2019 10:35 PM
