Maximum Call Park or Holds in CUCM
amansin74
  Hi All,
One question came in my mind when i saw 3-4 thousands of call park numbers configured.
Since these Call are held by CUCM,  How Many of them can a CUCM server support concurrently ?
Thanks in advance.
Aman
“If you have knowledge, let others light their candles in it.”
Chris Deren
I am not aware of a hard limit, this should not be a problem as this is really no different from having calls put on hold, if you are using unicast MOH you may run out of MOH resources, but I cannot think of any other downside.
HTH,
Chris
