Maximum Conference Calls 8831
Sebast123
Dear All,
We are planning for a BE6k solution with 8900 and 7800 series phones and 8831 conference phones. 2901 Voice Gateway with additional 32 Channel additional PVDM3 with 12 analog PSTN lines.
One of our requirement is to have more than 10 party audio conference call with 9 external recipients. Is this possible with the solution and the DSP resources are fine?
As per the 8831 user guide, maximum number of participants that can be displayed is 16 but Maximum outbound calls support is 6. So, does that mean that we can only have 6 dialed out calls in the conference and remaining calls can be inbound received calls.
What is the best way to achieve this solution.
Thanks much.
2 Accepted Solutions
Considering you have just CUCM and no conferencing applications, you can have either a Meet me or adhoc conference. Meet me will need you to dial a meet me number (it will open the bridge) and rest of the participants dial that number and are joined into conference. Its conigurable Service parameter in CUCM if using CUCM software bridge. (i think the limit is 128 participants)
Adhoc is when you dial someone, then press conference button. I think the limit for this type of conference is 64 (using CUCM software bridge). This is again configurable service param in CUCM with default value something like 4 or 6.
For both type of conf. you can use hardware based bridge, max number of participants will be dependant on resources available and configured.
Difference between hardware and software is - software based bridge only supports G711 so if you have call having different codecs (like G729) then you need a hardware based conf bridge which is capable of mixing streams of different codecs.
-Terry
Please rate all helpful posts
To clarify further, read this from the guide you are talking about:
Multiple calls per line
The conference station has a single line and supports a maximum of 6 calls. Unless you are in a conference, only one call can be connected at any time; other calls are automatically placed on hold.
The 6 number limit you are talking about is lets say you call A, then press new call and call B, call to A will automatically be put over hold. Then call another person C, Calls to A and B are put on hold automatically so you can up to 6 different calls on phone simultaneously.
However if you dial A, then conference B, Then C this is a single conference call.
I hope this clears your doubts.
Please do rate all helpful posts and mark the thread as answered if you have no other queries.
-Terry
8 Replies 8
Terry Cheema
Maximum outbound calls from same line is 6. But you dont need to dial more than once from the same line to participate in a conference. The number of conferences you can have will depend on the DSP/hardware conference bridge.
-Terry
Dear Terry,
Thanks for your prompt response.
In a single conference, if we need to include about 9-10 external users, then I guess I can only dial out to 6 numbers and include them in the conference. how about the other users, do I have to ask them to call me.
Is there is better way to create a conference as per my requirement.
-Terry
Thanks for your detailed replies Terry. Much appreciated. thanks.
No Worries - glad that helped. Please feel free to post back in case you have any further queries.
-Terry
I am getting the idea is that with a Cisco CP-8831 Conference call phone, only one call can be conferenced in at any given time. The CP-8831 can place as many a 6 calls but only one can participate in the conference call at any given time. Not sure how that is useful but so be it. Mainly I would like to verify that one caller only is allowed in conference. Also, as far as I can tell there are no settings or upgrades of firmware that can change this? Your thoughts are appreciated! -Cris
Conference capabilities are not at the phone level.. When you want to initiate a conference, the conference resource must be invoked. Check your configurations on the call control system—that’s why you’re unable to set up a conference.
It’s always advisable to start a new thread instead of replying to an old one, especially one already resolved.
Response Signature
-Terry
