Maximum number of concurrent phone calls on a phone
Mike Buyarski
Level 3
Level 3
we are running CUCM 10.5
i noticed that between our phones we can only have 2 concurrent calls before the 3rd person calling the user is sent directly to voice mail. is there a way i can increase that to 4?
Jaime Valencia
Adjust the maximum number of calls and busy trigger as needed.
java
if this helps, please rate
Jaime Valencia
java
is there a way to change the globally so i would not have to go to each line?
No, this setting is per line, but you can use BAT.
java
Hi.
You can use Bulk Administration Tool to update all lines in one shot.
Bulk Administration Tool --> Phones --> Add/Update Lines --> Update Lines
Query your Directory Numbers with preferred option, click Find
Look at found DNs and click next
Click on "Maximum Number of calls" and write the desired value
Click on "Run Immediately" than Submit.
Carlo
Please rate all helpful posts "The more you help the more you learn"
