Maximun number of clauses in route filter
crodriguez
I am trying to configure THO or LCR via Route Filters, Route Groups, Route Lists.
Is there a max number of clauses per Route list?
I am trying to create a route filter where Area Code == xxx and Office == xxx
Looks like I can only add up to 20-21 clauses. Anyway of changing this?
Jeffrey Knuckle
Yes, I believe its the number of characters.
no way to change it, the full clause cannot exceed 1024 characters. you'll need to create several filters
java
if this helps, please rate
java
