ā06-15-2023 02:34 PM
dear support can you help me on this eureur please
call outgoing is no work
1208 : 9 5006360ms.1 (21:43:47.720 UTC Thu Jun 15 2023) +-1 +21190 pid:100 Originate 0043814448189
dur 00:00:00 tx:0/0 rx:1022/20440 0 () dscp:0 media:0 audio tos:0xB8 video tos:0x0
IP 10.145.127.99:48786 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g729r8 TextRelay: off Transcoded No
media inactive detected:n media contrl rcvd:n/a timestamp:n/a
long duration call detected:n long dur callduration :n/a timestamp:n/a
LostPacketRate:0.00 OutOfOrderRate:0.00
120F : 11 5059800ms.2 (21:44:41.160 UTC Thu Jun 15 2023) +11660 +34710 pid:100 Originate 00439999212548
dur 00:00:23 tx:0/0 rx:1529/30580 0 () dscp:0 media:0 audio tos:0xB8 video tos:0x0
IP 10.145.127.98:49080 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g729r8 TextRelay: off Transcoded No
Solved! Go to Solution.
ā06-16-2023 06:47 AM
thank you can you give me correct command to give you all you need please on this os
ā06-16-2023 07:06 AM - edited ā06-16-2023 07:17 AM
Read the shared documents and learn in the process, if you still have questions please come back with the specific question(s). The intent of the community is not to provide you with a ready made configuration, with no effort on your part. See it as a valuable learning experience that will grow you're skill set and make you a better engineer.
I added some additional info to my previous post, please go back and read that. With a small amount of effort on your part it should be doable for you to get this straighten out so that you at least have a half descent set of dial peers and have activated the Cube functionality so that your router can act as an SBC.
ā06-15-2023 10:04 PM - edited ā06-15-2023 10:05 PM
Hello @angembaki2002,
If you could please provide more details about the specific issue you are experiencing with outgoing calls, as @Roger Kallberg suggest.
Thanks.
ā06-16-2023 04:33 AM
Please can someone really help me with this configuration when I do a test call with the CSIM SART command the first call goes through but when it cuts the second no longer goes through I must first reset the cisco for a call to go through Again
