Meet me call query - cisco call manager 7
jenny_flannigan
How many people can be involved in a meetme conference call.
Is this number set by default and can it be changed
bijin bharathan
I think it is 128 unicast audio streams.yes you can change the default value from service perameter.
http://www.cisco.com/application/pdf/paws/111892/meetme.pdf
Bijin
David Hailey
Jenny,
This is actually a CCM Service Parameter.  By default, the parameter is set to 4 but the maximum is 128 and depends on the capabilities of the conference bridge as well as whether you are using hardware or software conferencing resources.  A very common value I've found customers use is 6 or 8...but again, depends on your environment.
The parameter is called:
Maximum MeetMe Conference Unicast
Details:
This parameter specifies the maximum number of participants that are allowed in a single Unicast Meet-Me conference. The value of this field depends on the capabilities of the software/hardware conference bridge; for example, a software conference bridge conferences up to 128 participants. When a conference is created, the system automatically reserves a minimum of three streams, so specifying a value less than three allows a maximum of three participants.
Hailey
Please rate helpful posts!
