02-23-2011 12:12 AM - edited 03-16-2019 03:36 AM
Hi:
Would appreciate any pointers in resolving a MeetMe conferencing issue. Pressing the MeetMe button shows No Conference Bridge message. Following is the checklist:
1. The dspfarm profile 1 conference is not shut.
2. "show dspfarm all" shows the conferencing service is UP, ACTIVE and ASSOCIATED
3. Image is ipvoice_ivs-mz.124-24.T4 and CME is 7.1
4. sccp ccm line is pointing to version 7.0
5. telephone-service has the appropriate sdspfarm tags
6. ephone-template has the "conference admin" statement
Anything else I can check ?
Thanks for any suggestions.
02-23-2011 12:52 PM
Do you have conference meetme command under all the ephone-dn's which are supposed to join the conference? Also check for the conference hardware under the telephony service.
Have a look at the following thread. It may be of some help to you
https://supportforums.cisco.com/message/1123356
Hope that helps
Nitesh
PS: Pl rate helpful posts
02-23-2011 12:54 PM
Check this config doc as well
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeconf.html#wp1020601
Nitesh
PS:Rate helpful posts
